Aller au contenu principal
Dyson Pure Cool AM11 Remote Control Battery Replacement
AidenManchester
AidenManchester et un autre contributeur
Dernière mise à jour le December 29, 2023
2 minutes
Très facile
If your remote doesn’t work the first thing you should check is the battery; being a very simple device it's very likely that the battery has died. For the replacement all you are going to need is Phillips #1 Screwdriver and a new CR2032L coin cell battery. The battery should last you upwards of 10 years with normal use so don't expect to be back in this guide anytime soon.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Dyson Pure Cool AM11 Remote Control Battery Replacement, Remote Control Battery: étape 1, image 1 de 2 Dyson Pure Cool AM11 Remote Control Battery Replacement, Remote Control Battery: étape 1, image 2 de 2
    • Use a Phillips #1 screwdriver to loosen the screw at the base of the remote.
  2. Dyson Pure Cool AM11 Remote Control Battery Replacement: étape 2, image 1 de 1
    • The battery tray is spring loaded and should slide out on its own.
  3. Dyson Pure Cool AM11 Remote Control Battery Replacement: étape 3, image 1 de 2 Dyson Pure Cool AM11 Remote Control Battery Replacement: étape 3, image 2 de 2
    • The battery should come out with mild pressure applied to the bottom.
    • Insert a new CR2032L coin cell battery.
    • Make sure the new battery is inserted positive side up, there will be a small + symbol on the battery to indicate the positive side.
AidenManchester
Membre depuis le 11/01/23
252 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G7
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 73
Total : 695
