Aller au contenu principal
Emson Star Wars R2-D2 Humidifier Circuit Board Replacement
Mani Jaishanker
Mani Jaishanker et 2 autres contributeurs
Dernière mise à jour le May 24, 2017
15 minutes
Facile
Photos d’action
Nécessite plus d'images
The printed circuit board, located inside the device, is the primary component of the humidifier. The printed circuit board connects all the components base on the user input through the front dial. The LED light, heat sink, and the fan are connected to the circuit board. If the humidifier is plugged in and isn't showing any results of working, then something might be faulty in the printed circuit board. We will demonstrate how to remove and replace the printed circuit board if it's malfunctioning.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Emson Star Wars R2-D2 Humidifier Circuit Board Replacement, Circuit Board: étape 1, image 1 de 3 Emson Star Wars R2-D2 Humidifier Circuit Board Replacement, Circuit Board: étape 1, image 2 de 3 Emson Star Wars R2-D2 Humidifier Circuit Board Replacement, Circuit Board: étape 1, image 3 de 3
    • Use the bit driver with a 4 mm nut driver and a PH1 extender to remove the marked screws on the backside of the humidifier.
    • Once the screws are removed flip the humidifier on its bottom and gently remove the plate from the bottom case.
  2. Emson Star Wars R2-D2 Humidifier Circuit Board Replacement: étape 2, image 1 de 3 Emson Star Wars R2-D2 Humidifier Circuit Board Replacement: étape 2, image 2 de 3 Emson Star Wars R2-D2 Humidifier Circuit Board Replacement: étape 2, image 3 de 3
    • Locate the circuit board.
    • Unscrew the marked screws with a bit driver, a 4 mm nut driver and a PH1 extender.
    • Gently remove the circuit board.
2 autres ont terminé cette réparation.
Mani Jaishanker
Membre depuis le 02/15/17
228 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 8-5, Eyestone Spring 2017 Membre de l'équipe USF Tampa, Team 8-5, Eyestone Spring 2017
USFT-EYESTONE-S17S8G5
4 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 464
