Aller au contenu principal
Epson PowerLite  822 Plus Exhaust Fan Replacement
Emma Richey
Emma Richey et un autre contributeur
Dernière mise à jour le May 13, 2022
15 - 25 minutes
Modérée
This is a replacement guide for the exhaust fan for the Epson PowerLite 822 Plus. Model number EMP-822H. When the exhaust fan is not working as it should that is when the projector could overheat and cause it to not work. This guide will show you how to remove and replace the current exhaust fan in your projector.
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Epson PowerLite  822 Plus Exhaust Fan Replacement, Motherboard: étape 1, image 1 de 1
    • Flip the projector over.
    • Remove all 8 screws on the bottom of the projector.
  2. Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 2, image 1 de 2 Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 2, image 2 de 2
    • Now, flip the projector back over and pry the top of it open revealing the inside of the projector.
  3. Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 3, image 1 de 2 Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 3, image 2 de 2
    • Use the spudger to disconnect it from the motherboard.
  4. Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 4, image 1 de 2 Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 4, image 2 de 2
    • Using your finger gently move back and forth the JST cable that connects the top to the motherboard.
    • Now completely take off the top of the projector.
  5. Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 5, image 1 de 2 Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 5, image 2 de 2
    • Remove the 3 screws that secure the motherboard in place.
  6. Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 6, image 1 de 3 Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 6, image 2 de 3 Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 6, image 3 de 3
    • Gently move back and forth the 11 JST connectors until they come out.
  7. Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 7, image 1 de 2 Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 7, image 2 de 2
    • With the spudger lift the red plastic tabs from their connectors.
  8. Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 8, image 1 de 3 Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 8, image 2 de 3 Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 8, image 3 de 3
    • Lift the motherboard and disconnect the JST connector underneath.
  9. Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 9, image 1 de 1
    • Now, the motherboard is completely removed from the projector and you are ready to replace it.
  10. Epson PowerLite  822 Plus Exhaust Fan Replacement, Projector Lens: étape 10, image 1 de 3 Epson PowerLite  822 Plus Exhaust Fan Replacement, Projector Lens: étape 10, image 2 de 3 Epson PowerLite  822 Plus Exhaust Fan Replacement, Projector Lens: étape 10, image 3 de 3
    • Unscrew the four 6mm screws that hold together the fan bracket.
  11. Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 11, image 1 de 2 Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 11, image 2 de 2
    • Unscrew the four 6mm screws that secure the projector.
  12. Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 12, image 1 de 2 Epson PowerLite  822 Plus Exhaust Fan Replacement: étape 12, image 2 de 2
    • Pull out the loose projector.
  13. Epson PowerLite  822 Plus Exhaust Fan Replacement, Exhaust Fan: étape 13, image 1 de 2 Epson PowerLite  822 Plus Exhaust Fan Replacement, Exhaust Fan: étape 13, image 2 de 2
    • Gently lift the fan bracket up and remove it and it is ready to be replaced.
Emma Richey
Membre depuis le 03/21/22
915 Réputation
5 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 120
