Aller au contenu principal
Epson PowerLite 77c Lamp Replacement
Gretchen Thomas
Gretchen Thomas et un autre contributeur
Dernière mise à jour le May 31, 2022
5 minutes
Facile
This guide demonstrates how to replace an Epson PowerLite 77c (V11H254220) lamp, part number V13H010L41. The projection lamp is the heart of a projector, as it lights and displays images. If you're experiencing issues involving a dim image, or if the lamp isn't illuminating at all when the projector is on, it's probably time to replace the lamp. Issues with the lamp are typically indicated by a flashing orange light under the power button.
There is mercury in the device’s lamp; therefore, there are state and local regulations regarding disposal and recycling. Do not discard in the trashcan.
Before removing the lamp, be sure power down and unplug the device; allow it to fully cool before beginning.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Epson PowerLite 77c Lamp Replacement, Lamp: étape 1, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the one 5.0 mm screw from the lamp cover on the back of the device.
  2. Epson PowerLite 77c Lamp Replacement: étape 2, image 1 de 1
    • Slide the cover toward you, then lift it to remove it.
  3. Epson PowerLite 77c Lamp Replacement: étape 3, image 1 de 2 Epson PowerLite 77c Lamp Replacement: étape 3, image 2 de 2
    • Loosen the two 5.0 mm captive screws with a Phillips #0 screwdriver.
    • Captive screws cannot be fully removed. Simply loosen the captive screws until the lamp housing releases, but do not attempt to remove them.
    • Pinch the two release triggers to unlatch the lamp housing, and lift upward to remove it.
Gretchen Thomas
Membre depuis le 02/08/22
211 Réputation
2 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 257
