Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Epson PowerLite 83+ Fan Replacement
Ce dont vous avez besoin
  1. Epson PowerLite 83+ Fan Replacement, Motherboard: étape 1, image 1 de 3 Epson PowerLite 83+ Fan Replacement, Motherboard: étape 1, image 2 de 3 Epson PowerLite 83+ Fan Replacement, Motherboard: étape 1, image 3 de 3
    • Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
    • A long shank Phillips #2 screwdriver is required to reach the screws.
    Demander à FixBot
    Ajouter un commentaire
  2. Epson PowerLite 83+ Fan Replacement: étape 2, image 1 de 3 Epson PowerLite 83+ Fan Replacement: étape 2, image 2 de 3 Epson PowerLite 83+ Fan Replacement: étape 2, image 3 de 3
    • Flip the projector over and lift the top cover from the rear of the projector.
    • Two cables are connected at the front that prevent full removal.
    • Disconnect the slide cover JST connector. Grip the connector and rock it back and forth while apply gentle pressure.
    Demander à FixBot
  3. Epson PowerLite 83+ Fan Replacement: étape 3, image 1 de 2 Epson PowerLite 83+ Fan Replacement: étape 3, image 2 de 2
    • Using a spudger, lift the ribbon cable's locking tab along the length of the cable.
    • Remove the ribbon cable from the connector and place the projector's top cover aside.
    Demander à FixBot
  4. Epson PowerLite 83+ Fan Replacement: étape 4, image 1 de 3 Epson PowerLite 83+ Fan Replacement: étape 4, image 2 de 3 Epson PowerLite 83+ Fan Replacement: étape 4, image 3 de 3
    • Remove the two 6 mm Phillips #2 screws.
    • Remove the single silver 5 mm Phillips #2 screw.
    Demander à FixBot
  5. Epson PowerLite 83+ Fan Replacement: étape 5, image 1 de 3 Epson PowerLite 83+ Fan Replacement: étape 5, image 2 de 3 Epson PowerLite 83+ Fan Replacement: étape 5, image 3 de 3
    • Using your fingernails or a spudger, remove the eleven JST connectors attached to the motherboard.
    Demander à FixBot
  6. Epson PowerLite 83+ Fan Replacement: étape 6, image 1 de 2 Epson PowerLite 83+ Fan Replacement: étape 6, image 2 de 2
    • Using a spudger, flip up the plastic locking tabs and gently remove the three ribbon cables from their connectors.
    Demander à FixBot
  7. Epson PowerLite 83+ Fan Replacement: étape 7, image 1 de 2 Epson PowerLite 83+ Fan Replacement: étape 7, image 2 de 2
    • Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
    • Lift the motherboard from the front side of the projector to clear the ribbon cables.
    • Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
    • Remove the motherboard from the case.
    Demander à FixBot
  8. Epson PowerLite 83+ Fan Replacement, Exhaust Fan: étape 8, image 1 de 2 Epson PowerLite 83+ Fan Replacement, Exhaust Fan: étape 8, image 2 de 2
    • Loosen the two captive Phillips #2 screws securing the lamp.
    • Captive screws should not be removed. They are secured to the lamp itself with retaining rings and will be removed along with the lamp.
    Demander à FixBot
  9. Epson PowerLite 83+ Fan Replacement: étape 9, image 1 de 1
    • Hold onto the indented areas of the lamp with your fingers and gently pull it upwards to remove it from the casing.
    Demander à FixBot
  10. Epson PowerLite 83+ Fan Replacement: étape 10, image 1 de 3 Epson PowerLite 83+ Fan Replacement: étape 10, image 2 de 3 Epson PowerLite 83+ Fan Replacement: étape 10, image 3 de 3
    • Remove the four 6 mm Phillips #2 screws.
    • Lift the fan bracket straight up to remove it from the casing.
    Demander à FixBot
  11. Epson PowerLite 83+ Fan Replacement: étape 11, image 1 de 2 Epson PowerLite 83+ Fan Replacement: étape 11, image 2 de 2
    • A long, thin shank Phillips #2 screwdriver is required to remove the screws.
    Demander à FixBot
  12. Epson PowerLite 83+ Fan Replacement: étape 12, image 1 de 2 Epson PowerLite 83+ Fan Replacement: étape 12, image 2 de 2
    • Remove the exhaust fan from the bracket.
    Demander à FixBot
Billy Fox
Membre depuis le 02/22/22
467 Réputation
3 tutoriels rédigés
Équipe
Clemson, Team 2-4, Hunter Spring 2022 Membre de l'équipe Clemson, Team 2-4, Hunter Spring 2022
CLEM-HUNTER-S22S2G4
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 552
