Epson Powerlite S4 Front Adjustable Foot Replacement
Introduction
Passez à l'étape 1This guide will show you how to replace the adjustable foot in the Epson Powerlite S4 projector. The adjustable foot is a component used to raise or lower the projected image. It can be found next to the lens at the front of the power light. If the adjustable foot is unable to be adjusted, it may need to be replaced.
Ce dont vous avez besoin
To the left of the lens, you'll find the adjustable foot.
Remove the screw to the left of the adjustable foot using a Phillips #0 screwdriver.
Lift up the adjustable foot to remove it from the projector.
