Aller au contenu principal
Fitbit Surge GPS Replacement
Angela Pitts
Angela Pitts et 2 autres contributeurs
Dernière mise à jour le October 10, 2017
20 minutes
Modérée
Having trouble with your Fitbit Surge's GPS? Read this guide to learn how to replace the GPS, but keep in mind that you will need to cut the wristband in order to complete this repair and the band cannot be reattached.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Fitbit Surge GPS Replacement, Fitbit Surge GPS Replacement: étape 1, image 1 de 2 Fitbit Surge GPS Replacement, Fitbit Surge GPS Replacement: étape 1, image 2 de 2
    • Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
  2. Fitbit Surge GPS Replacement: étape 2, image 1 de 3 Fitbit Surge GPS Replacement: étape 2, image 2 de 3 Fitbit Surge GPS Replacement: étape 2, image 3 de 3
    • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
    • Note: Part of the band is hard plastic.
    • Caution: Once the band is cut it cannot be reattached.
  3. Fitbit Surge GPS Replacement: étape 3, image 1 de 2 Fitbit Surge GPS Replacement: étape 3, image 2 de 2
    • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
  4. Fitbit Surge GPS Replacement: étape 4, image 1 de 2 Fitbit Surge GPS Replacement: étape 4, image 2 de 2
    • Use a PH000 screw head to undo the newly revealed 4 mm Phillips screws that were hidden beneath the glue.
To reassemble your device, follow these instructions in reverse order. Keep in mind that you will need to cut the band for this guide and it cannot be reattached.
3 autres ont terminé cette réparation.
Angela Pitts
Membre depuis le 10/11/16
1 187 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 1-3, Leahy Fall 2016 Membre de l'équipe USF Tampa, Team 1-3, Leahy Fall 2016
USFT-LEAHY-F16S1G3
3 membres
4 tutoriels rédigés
1 commentaire de tutoriel
Where do you get the parts to replace the GPS or the screen ?
Christine Arends - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 3,000
