Aller au contenu principal
FlySky FS-TH9X Joystick Replacement
Heath Soucheck
Heath Soucheck et 3 autres contributeurs
Dernière mise à jour le June 12, 2023
10 minutes
Modérée
Nécessite plus d'images
Étapes manquantes
Over continued use, the joystick tends to move on it's own without you moving the joystick. This is fixable by replacing the entire joystick. This guide consist of the steps required to open the remote, dislocate the joysticks and than replacing said joysticks.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. FlySky FS-TH9X Joystick Replacement, FlySky FS-TH9X Disassembly: étape 1, image 1 de 1
    • On the back of the remote, you will see 6 5mm Phillips #2 head screws.
    • The six screws on the front of the remote are screws that disconnect the joysticks from the remote and cannot be used to remove the back panel.
  2. FlySky FS-TH9X Joystick Replacement: étape 2, image 1 de 1
    • Using a size two Phillips screwdriver, remove the six 5 mm Phillips #2 head screws
  3. FlySky FS-TH9X Joystick Replacement: étape 3, image 1 de 1
    • Using a pry tool with a little pressure, carefully pull apart the remote to expose the inside.
  4. FlySky FS-TH9X Joystick Replacement: étape 4, image 1 de 1
    • Continue to troubleshooting your device.
  5. FlySky FS-TH9X Joystick Replacement, FlySky FS-TH9X Joystick: étape 5, image 1 de 1
  6. FlySky FS-TH9X Joystick Replacement: étape 6, image 1 de 1
    • Carefully remove chassis from outer casing.
  7. FlySky FS-TH9X Joystick Replacement: étape 7, image 1 de 1
    • Gently remove wiring from circuit.
    • To replace this part please contact the manufacturer, or consult the internet, to purchase parts.
Heath Soucheck
Membre depuis le 02/09/23
715 Réputation
5 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 189
