Aller au contenu principal
Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement
Jose Colunga
Jose Colunga et 2 autres contributeurs
Dernière mise à jour le May 10, 2019
15 - 25 minutes
Modérée
Male RCA plugs can easily break off inside of a port if the cable is stepped on or if it is removed by pulling on the cable, instead of the head. This tutorial shows the removal process of a stuck pin.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement, RCA Male Plug: étape 1, image 1 de 1
    • Using wire cutters cut the wires and strip 2 centimeters of sheathing from the ends.
  2. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: étape 2, image 1 de 1
    • Peel the shielding from the wiring to expose the two separate wires.
  3. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: étape 3, image 1 de 2 Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: étape 3, image 2 de 2
    • Place 2 - 3 inches of thicker heat shrink tubing over the main wiring.
    • Place 2-3 centimeters of a thinner heat shrink for the individual wiring, where the plastic sheathing was trimmed.
  4. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: étape 4, image 1 de 1
    • Connect the wires and hold them in place.
    • Due to the lack of complex electronics in the speaker, as long as both wires have a connection, the speaker will work.
  5. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: étape 5, image 1 de 2 Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: étape 5, image 2 de 2
    • While the two wires are connected, place the solder metal over the wires.
    • Bond the wires together by pressing the soldering iron over the solder, until the solder covers where the wires connect.
    • Do not to touch the soldering iron or the melted solder until they cool for a few minutes.
  6. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: étape 6, image 1 de 1
    • Cover the exposed wires with the thinner heat shrink tubing.
  7. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: étape 7, image 1 de 2 Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: étape 7, image 2 de 2
    • Use the heat gun to shrink the tubing around the connected wires.
    • Hold the wires with a tool or an oven mitt to avoid burning yourself with the heat gun.
  8. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: étape 8, image 1 de 1
    • Move the thicker heat shrink tubing over the smaller heat shrink tubing.
    • Use a heat gun to shrink the tubing in place.
  9. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: étape 9, image 1 de 1
    • Showing the clogged port.
  10. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: étape 10, image 1 de 1
    • Heat the tip of a thin screwdriver with an average lighter.
    • Use a tool or an oven mitt to hold the screwdriver to avoid any burns.
  11. Frisby 5.1 Surround Sound FS-5000 BT Audio RCA Male Plug Replacement: étape 11, image 1 de 1
    • Hold the screwdriver tip inside the clogged port for 3 - 5 minutes.
    • Using a wrench to hold the screw driver, use a hammer to keep weight on the screwdriver.
    • This allows the screwdriver to melt through any plastic from the RCA male plug and reach the metal tip inside the port.
    • Remove the pin when it has bonded to the screwdriver.
Ligne d'arrivée
Jose Colunga
Membre depuis le 01/31/19
193 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 199
