Aller au contenu principal
Fujinon XF 18mm F2 lens Disassembly
yukosteel
yukosteel et 2 autres contributeurs
Dernière mise à jour le June 26, 2024
30 minutes
Modérée
Tutoriel réalisé par la communauté
Ce dont vous avez besoin
Outils
  1. Fujinon XF 18mm F2 lens Disassembly, Lens: étape 1, image 1 de 1
    • Step one is classical for XF lens – unscrew four silver and three black bolts, remove black plastic inner cylinder, release contacts module and finally remove mount ring.
  2. Fujinon XF 18mm F2 lens Disassembly: étape 2, image 1 de 1
    • You may find few tiny metal shims at mount bolt connection points. My lens has just one. Memorize shim position and put it back when assembling for proper optical alignment. Also, remove dark foam bar – it serves to hold electronics board in place.
    • Then unscrew two black bolts (marked in blue), and accurately release three ribbon cables. Make sure you don’t touch electronic board surfaces, keep it by holding edges – it’s important!
  3. Fujinon XF 18mm F2 lens Disassembly: étape 3, image 1 de 1
    • Now remove electronic board, but do not put it on the surface.
  4. Fujinon XF 18mm F2 lens Disassembly: étape 4, image 1 de 1
    • Electronic board has special section for aperture ring contacts, and it is covered with thin layer of lubricant. I never saw that in any electronic lens disassembled before, so be very attentive and don’t accidentally wipe that lubricant (or sealing gel, I don’t exactly know its purpose).
    • Then unscrew two black bolts and take out AF drive module.
  5. Fujinon XF 18mm F2 lens Disassembly: étape 5, image 1 de 1
    • At this point you can unscrew three black bolts holding aperture ring module.
  6. Fujinon XF 18mm F2 lens Disassembly: étape 6, image 1 de 1
    • Remove aperture ring. You’ll see “focus by wire” focus ring sensors. To remove focus ring without damaging senors, slightly press on it’s sides to make some space for sensors, then remove it.
  7. Fujinon XF 18mm F2 lens Disassembly: étape 7, image 1 de 1
    • Now you have good access to inner real focusing ring. I spent some time adding extra grease to focusing gear thread. You can manually rotate this ring to change core module focus position.
  8. Fujinon XF 18mm F2 lens Disassembly: étape 8, image 1 de 1
    • That is final disassembly point which can be easily done. Assemble lens back in reversive order.
    • However if you very much need to have access under the rear glass module the extreme challenge is starting at this point. I had to remove large 1.5mm wide dust particle, so I didn’t find other options but spend about 30 minutes accurately cutting out white factory glue piece by piece.
    • It’s very messy process generating tons of glue particles. After finishing that I also used very thin flat screwdriver to apply additional pressure between rear module plastic frame and lens core cylinder. Rotating rear lens frame about 15 degrees CCW allows to remove it.
  9. Fujinon XF 18mm F2 lens Disassembly: étape 9, image 1 de 1
    • I’ve spent another 10 minutes removing glue particles from surfaces, and used air blowing to remove most accidental particles traveled inside. As a result I cleared that huge dust particle under the rear glass, but it was hard process : )
    • Alternative way to access inner glass surface of aperture chamber is to disassemble front area.
    • I’m using double sided thick adhesive tape and empty frame from lens filter. Add tape pieces like shown on picture.
  10. Fujinon XF 18mm F2 lens Disassembly: étape 10, image 1 de 1
    • Unscrewing nameplate ring requires rapid torque movement CCW to break few dots of factory glue inside. Then it goes smooth until completely unscrewed from lens filter thread. Ring consists of two parts – thick plastic frame with side thread, and thin metal front plate with lens naming details.
  11. Fujinon XF 18mm F2 lens Disassembly: étape 11, image 1 de 1
    • There is also a foam ring to block dust from entering area around front lens glass. Now you can unscrew three black bolts holding filter thread ring.
  12. Fujinon XF 18mm F2 lens Disassembly: étape 12, image 1 de 1
    • After removing front ring you have better access to lens optical core. At this point I’m stopping disassembly, because this lens sample works great and is clean inside.
    • However if I had to access aperture chamber my next step would be unscrewing remaining six bolts, and try to accurately break the glue to remain it on frame parts.
    • It’s important to understand that optical frame position is precisely calibrated on Fuji factory and glue is applied to hold exact position firm. If you preserve the glue on all location, there is a higher chance you can put frame back in properly aligned place.
Fujinon XF 18mm F2 lens has very interesting construction and electronics position. It’s relatively easy to disassemble lens mechanically and access electronics. However all the optics from rear side sits inside plastic frames firmly glued together. It’s not like XF 27mm where only few tiny glue drops hold rear module – XF 18mm has tons of solid and very hard glue. So accessing optics for cleaning is extremely difficult.
yukosteel
Membre depuis le 04/27/18
583 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 16
30 derniers jours : 58
Total : 2,734
