Aller au contenu principal
G603 Wheel Encoder Replacement
Jim
Jim et un autre contributeur
Dernière mise à jour le February 24, 2025
10 - 20 minutes
Facile
Tutoriel réalisé par la communauté
Logitech G603 mouse wheel encoder replacement.
The encoder is a Logitech 210-001795. It's possible the PCB color on replacements is different than what's inside the G603.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. G603 Wheel Encoder Replacement, Remove Top Cover & Batteries: étape 1, image 1 de 1
    • Remove magnetic top cover, batteries, and wireless receiver (if currently stored inside the mouse)
  2. G603 Wheel Encoder Replacement, Remove Mouse Feet: étape 2, image 1 de 3 G603 Wheel Encoder Replacement, Remove Mouse Feet: étape 2, image 2 de 3 G603 Wheel Encoder Replacement, Remove Mouse Feet: étape 2, image 3 de 3
    • Carefully remove the feet to reveal the 4 screws holding the top and bottom shells together
    • NOTE: These feet can be removed carefully enough to be reused. Only the top and bottom feet need to be removed, not the one around the sensor
  3. G603 Wheel Encoder Replacement, Remove the four Phillips #00 Screws: étape 3, image 1 de 1
    • Use Phillips #00 to remove the four bottom screws
  4. G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: étape 4, image 1 de 3 G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: étape 4, image 2 de 3 G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: étape 4, image 3 de 3
    • Start at the top above the left and right click and slowly work your way around the shells until they are separated
    • Be careful not to damage the power connector or ribbon cable going from the top shell's boards/battery to the bottom shell's board
  5. G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: étape 5, image 1 de 3 G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: étape 5, image 2 de 3 G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: étape 5, image 3 de 3
    • Start with the red and black power cable and gently pull it out
    • Once power cable is removed, you should be able to unfold the two halves and unplug the white ribbon cable
  6. G603 Wheel Encoder Replacement, Remove Encoder Ribbon Cable: étape 6, image 1 de 1
    • Gently pull out the black ribbon cable connecting the encoder board to the main board
  7. G603 Wheel Encoder Replacement, Remove 5 Phillips #00 Screws: étape 7, image 1 de 1
    • Remove the Phillips #00 screws holding the encoder board in place
  8. G603 Wheel Encoder Replacement, Remove Encoder Board & Wheel: étape 8, image 1 de 1
    • Remove the encoder board from the bottom shell
    • Gently remove the wheel from the older encoder board
    • NOTE: The old wheel can be reused in the replacement encoder board
Jim
Membre depuis le 06/17/23
331 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 23
30 derniers jours : 127
Total : 3,405
