Aller au contenu principal
GARDENA Smart Gateway Repair
Computerix
Computerix et un autre contributeur
Dernière mise à jour le March 31, 2024
1 heure
Modérée
Tutoriel réalisé par la communauté
If the GARDENA smart Gateway can no longer be powered on there may be various reasons which are easy to fix. This guide refers to the fuses installed in the device.
  1. GARDENA Smart Gateway Repair, Open device: étape 1, image 1 de 2 GARDENA Smart Gateway Repair, Open device: étape 1, image 2 de 2
    • Remove the rubber feet. Below are four Torx T9 screws.
  2. GARDENA Smart Gateway Repair, Fuse: étape 2, image 1 de 1
    • Identify if the fuse is blown. Take a multimeter and measure the resistance. There should be no measurable resistance.
    • If the fuse is defective it should be replaced with a new one. Component listed under parts.
  3. GARDENA Smart Gateway Repair, TVS Diode: étape 3, image 1 de 1
    • Second component likely to fail is the TVS Diode (Transient-voltage-suppression diode). It is used to protect the sensitive circuit from overvoltage.
    • Measure the resistance on the two terminals. Resistance should be infinite.
    • If component is broken the circuit is shorted. Therefore the component can be removed in order to repair the device. Afterwards the circuit is not protected against overvoltage anymore!
  4. GARDENA Smart Gateway Repair, Test the device: étape 4, image 1 de 1
    • Power LED should light up green
Computerix
Membre depuis le 05/24/23
374 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 21
Total : 663
