Aller au contenu principal
GoPro Hero 4 Black USB Replacement
Jonathan Campbell
Jonathan Campbell et 8 autres contributeurs
Dernière mise à jour le May 7, 2024
35 minutes
Modérée
Découpez pour améliorer
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
If you are having trouble with your USB connection you might need to replace the USB port. This is a guide for replacing the USB connection port on the Hero4 Black.
Ce dont vous avez besoin
Outils
  1. GoPro Hero 4 Black USB Replacement, Replacing USB Port: étape 1, image 1 de 1
    • First, you will have to remove the faceplate by carefully using the spudger around the edge to loosen the clips.
    • After loosening the clips on the edge, pull the faceplate off.
    • Be aware that there is double-sided tape on the backside of the faceplate (indicated by the red arrow).
  2. GoPro Hero 4 Black USB Replacement: étape 2, image 1 de 1
    • Now, you will need to take a PH000 Philips head screwdriver and remove the 4 corner screws.
    • Note: The screws circled in red are longer than the screw circled in orange.
  3. GoPro Hero 4 Black USB Replacement: étape 3, image 1 de 1
    • Now, you will need to remove the camera and boards from the black plastic housing. You may use any tool that will do the job. My group found out, if you use the plastic tool to remove the boards and camera, that it would assist you with the removal.
  4. GoPro Hero 4 Black USB Replacement: étape 4, image 1 de 1
    • Remove the ribbon strip by carefully pulling on it. It should slide out of its connection.
    • When you push down on the three wires that are connected to the clip. The clip will disconnect from the motherboard.
  5. GoPro Hero 4 Black USB Replacement: étape 5, image 1 de 1
    • Take yourPH000 Philips head screwdriver to remove the four screws outlined in red.
    • Once the screws are removed. Gently remove the board and as you lift the board, the computer chip (outlined in orange) will separate from the motherboard.
  6. GoPro Hero 4 Black USB Replacement: étape 6, image 1 de 1
    • Take your PH000 Philips head screwdriver and remove the three screws that are outlined in red.
    • Just like before, gently pull up on the ribbon strip to remove the connector from the motherboard.
  7. GoPro Hero 4 Black USB Replacement: étape 7, image 1 de 1
    • Remove the two screws to remove the riser that is being held in place by the screws.
  8. GoPro Hero 4 Black USB Replacement: étape 8, image 1 de 1
    • Remove a single screw located near the barcode.
    • Note: Once the screw is removed, only the ribbon strip on the bottom of the motherboard is holding it.
  9. GoPro Hero 4 Black USB Replacement: étape 9, image 1 de 1
    Outil utilisé dans cette étape :
    • At the top of the ribbon strip, there is a black clip that will need to be popped up.
    • Note: You can use your finger to pop the clip, but a pair of tweezers might be of help.
  10. GoPro Hero 4 Black USB Replacement: étape 10, image 1 de 1
    • Gently, grab the ribbon with a pair of tweezers to disconnect the ribbon from the connecter.
    • Now, the motherboard can be removed. Due to the USB connector being soldered to the motherboard, the entire board will need to be replaced.
8 autres ont terminé cette réparation.
Jonathan Campbell
Membre depuis le 09/29/15
830 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 1-2, Hagerty Fall 2015 Membre de l'équipe IUPUI, Team 1-2, Hagerty Fall 2015
IUPUI-HAGERTY-F15S1G2
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 18
Total : 3,683
