Aller au contenu principal
GoPro Karma Propeller Replacement
Jay Ingram
Jay Ingram et 2 autres contributeurs
Dernière mise à jour le August 2, 2019
7 - 10 minutes
Très facile
The propellers are a very common broken part due to their relative fragility on a drone. Luckily, it is a very easy replacement, and the drone even comes with a few spares. The GoPro Karma wrench is a tool that comes with the drone to hold the motor in place to remove the propellers. Spare ones can be bought on ebay but are not available for purchase from the GoPro site.
  1. GoPro Karma Propeller Replacement, Battery: étape 1, image 1 de 1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Propeller Replacement, Stabilizer: étape 2, image 1 de 3 GoPro Karma Propeller Replacement, Stabilizer: étape 2, image 2 de 3 GoPro Karma Propeller Replacement, Stabilizer: étape 2, image 3 de 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Propeller Replacement: étape 3, image 1 de 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Propeller Replacement, Propeller: étape 4, image 1 de 3 GoPro Karma Propeller Replacement, Propeller: étape 4, image 2 de 3 GoPro Karma Propeller Replacement, Propeller: étape 4, image 3 de 3
    • Extend the arms and set the drone face up.
    • The front right and back left propellers unscrew clockwise.
    • The front left and back right propellers unscrew counterclockwise.
  5. GoPro Karma Propeller Replacement: étape 5, image 1 de 2 GoPro Karma Propeller Replacement: étape 5, image 2 de 2
    • Place the GoPro Karma wrench on the motor.
    • Hold the motor in place with the wrench and unscrew the propeller in the indicated direction.
Jay Ingram
Membre depuis le 04/19/18
334 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S25-G14, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 membres
6 tutoriels rédigés
2 commentaires de tutoriel
You got it the wrong way around, to take them off you need to do the exact opposite to what you say.
michael.woelk - Réponse
hi, i am trying to fix my Karma. I have to remove the propellers but it is like they are stocked.
I try to unscrew the propellers but i can’t remove them.
Do you know what to do in this case?
Davide Negro - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 19
Total : 1,722
