Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixel 7 Pro Earpiece Speaker Replacement
Ce dont vous avez besoin
    1. Google Pixel 7 Pro Earpiece Speaker Replacement, Safety precautions: étape 1, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Safety precautions: étape 1, image 2 de 2
      • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
      • Fully power off your phone and unplug any cables.
      Demander à FixBot
      Ajouter un commentaire
    2. Google Pixel 7 Pro Earpiece Speaker Replacement, Screen removal information: étape 2, image 1 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Screen removal information: étape 2, image 2 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Screen removal information: étape 2, image 3 de 3
      • The screen of the Google Pixel 7 Pro is held in place by plastic clips and adhesive. Note the following:
      • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
      • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
      • During the removal procedure, make sure to insert your opening picks in the right position to avoid separating the screen from its safety frame.
      • Only insert the pick up to ~3.5 mm during the removal procedure to avoid damaging the internals and to avoid interfering with the plastic clips.
      • There are several plastic clips around the whole screen. If your opening pick gets blocked during the screen removal procedure, you've inserted your pick too deep underneath the screen.
      Demander à FixBot
    3. Google Pixel 7 Pro Earpiece Speaker Replacement, Anti-Clamp instructions: étape 3, image 1 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Anti-Clamp instructions: étape 3, image 2 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Anti-Clamp instructions: étape 3, image 3 de 3
      Outil utilisé dans cette étape :
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your phone.
      • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction.
      • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Demander à FixBot
    4. Google Pixel 7 Pro Earpiece Speaker Replacement: étape 4, image 1 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement: étape 4, image 2 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement: étape 4, image 3 de 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Demander à FixBot
    5. Google Pixel 7 Pro Earpiece Speaker Replacement: étape 5, image 1 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement: étape 5, image 2 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement: étape 5, image 3 de 3
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the phone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next two steps.
      Demander à FixBot
    6. Google Pixel 7 Pro Earpiece Speaker Replacement, Loosen the display adhesive: étape 6, image 1 de 1
      • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
      Demander à FixBot
    7. Google Pixel 7 Pro Earpiece Speaker Replacement, Insert an opening pick: étape 7, image 1 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Insert an opening pick: étape 7, image 2 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Insert an opening pick: étape 7, image 3 de 3
      • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
      • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the bottom edge and try again.
      • Insert an opening pick into the gap.
      Demander à FixBot
    8. Google Pixel 7 Pro Earpiece Speaker Replacement, Prevent damage to your phone: étape 8, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Prevent damage to your phone: étape 8, image 2 de 2
      • To avoid damaging your phone, don't insert your pick more than ~2.5 mm as you separate the screen adhesive. Note the following areas:
      • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
      • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
      Demander à FixBot
    9. Google Pixel 7 Pro Earpiece Speaker Replacement, Slice the bottom edge adhesive: étape 9, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Slice the bottom edge adhesive: étape 9, image 2 de 2
      • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Demander à FixBot
    10. Google Pixel 7 Pro Earpiece Speaker Replacement: étape 10, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement: étape 10, image 2 de 2
      • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
      • There's a plastic clip in the bottom left corner that will block your opening pick. Only use the tip of the opening pick (~1 mm) to work your way around it.
      Demander à FixBot
    11. Google Pixel 7 Pro Earpiece Speaker Replacement, Release the left clips: étape 11, image 1 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Release the left clips: étape 11, image 2 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Release the left clips: étape 11, image 3 de 3
      • Insert a third opening pick underneath the bottom left corner of the screen.
      • Slide the opening pick along the left edge of the screen to slice the adhesive and to release the plastic clips.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Demander à FixBot
    12. Google Pixel 7 Pro Earpiece Speaker Replacement, Slice the top edge adhesive: étape 12, image 1 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Slice the top edge adhesive: étape 12, image 2 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Slice the top edge adhesive: étape 12, image 3 de 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
      • When you slice near the front facing camera, insert only the tip of the opening pick (~2.5 mm) to avoid damaging or smearing the camera.
      • Insert a fourth opening pick at the top left corner of the screen.
      • Slide the opening pick along the top edge of the phone to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Demander à FixBot
    13. Google Pixel 7 Pro Earpiece Speaker Replacement, Release the right clips: étape 13, image 1 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Release the right clips: étape 13, image 2 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Release the right clips: étape 13, image 3 de 3
      • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive and release the right plastic clips.
      • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly by a flex cable.
      Demander à FixBot
    14. Google Pixel 7 Pro Earpiece Speaker Replacement, Open up the phone: étape 14, image 1 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Open up the phone: étape 14, image 2 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Open up the phone: étape 14, image 3 de 3
      • Lift the right edge of the screen up and towards the left side of the device, like opening a book.
      • Don't twist the screen or move it too far away from the frame to avoid straining or damaging the flex cable.
      • Rest the screen upside down and parallel to the frame.
      Demander à FixBot
    15. Google Pixel 7 Pro Earpiece Speaker Replacement, Release the display cable bracket: étape 15, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Release the display cable bracket: étape 15, image 2 de 2
      • The display cable bracket sits tightly and requires some force to release it.
      • Insert one arm of a pair of tweezers into the opening at the upper end of the display cable bracket.
      • Push the bracket inwards and pry up to release it.
      Demander à FixBot
    16. Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the display cable bracket: étape 16, image 1 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the display cable bracket: étape 16, image 2 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the display cable bracket: étape 16, image 3 de 3
      • Use a pair of tweezers to remove the display cable bracket by pulling it from underneath the midframe and in direction of the camera.
      Demander à FixBot
    17. Google Pixel 7 Pro Earpiece Speaker Replacement, Disconnect the display cable: étape 17, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Disconnect the display cable: étape 17, image 2 de 2
      • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Demander à FixBot
    18. Google Pixel 7 Pro Earpiece Speaker Replacement, Screen information: étape 18, image 1 de 1
      • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
      • To prevent damaging your screen or replacement screen:
      • When handling your screen, grip it by its edges.
      • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
      Demander à FixBot
    1. Google Pixel 7 Pro Earpiece Speaker Replacement, Separate the screen: étape 19, image 1 de 1
      • Separate the screen from the phone assembly.
      • During reassembly:
      • Check that all screws are tightened and there are no loose parts.
      • Reconnect the screen and test your phone to make sure it works. Power it back down and continue reassembly.
      • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Follow this guide if you're using custom-cut adhesives for your device.
      • Follow this guide in case you're using a pre-cut adhesive card.
      • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
      Demander à FixBot
    1. Google Pixel 7 Pro Earpiece Speaker Replacement, Peel off the graphite foil: étape 20, image 1 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Peel off the graphite foil: étape 20, image 2 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Peel off the graphite foil: étape 20, image 3 de 3
      • Use a pair of tweezers to carefully peel the graphite foil off the battery and midframe.
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      • If you're having a hard time peeling off the foil, you can apply a heated iOpener to the back of the device for two minutes to loosen its adhesive.
      Demander à FixBot
    2. Google Pixel 7 Pro Earpiece Speaker Replacement, Unfasten the charging port bracket screws: étape 21, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Unfasten the charging port bracket screws: étape 21, image 2 de 2
      • Use a Torx T3 screwdriver to remove the two 5.1 mm-long screws securing the charging port bracket.
      Demander à FixBot
    3. Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the charging port bracket: étape 22, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the charging port bracket: étape 22, image 2 de 2
      • Use a pair of tweezers to remove the charging port bracket.
      Demander à FixBot
    4. Google Pixel 7 Pro Earpiece Speaker Replacement, Unfasten the midframe screws: étape 23, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Unfasten the midframe screws: étape 23, image 2 de 2
      • Use a Torx T3 screwdriver to remove the six 5.1 mm-long screws securing the midframe.
      Demander à FixBot
    5. Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the midframe: étape 24, image 1 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the midframe: étape 24, image 2 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the midframe: étape 24, image 3 de 3
      • Use a pair of tweezers to remove the midframe.
      • During reassembly check the condition of the thermal pad. If it's damaged, remove the pad, clean the area with high-concentration (greater than 90%) isopropyl alcohol and a microfiber or lint-free cloth, and apply a new thermal pad.
      Demander à FixBot
    1. Google Pixel 7 Pro Earpiece Speaker Replacement, Disconnect the battery cable: étape 25, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Disconnect the battery cable: étape 25, image 2 de 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      Demander à FixBot
    1. Google Pixel 7 Pro Earpiece Speaker Replacement, Unfasten the mmWave antenna bracket screw: étape 26, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Unfasten the mmWave antenna bracket screw: étape 26, image 2 de 2
      • The next seven steps show how to remove the mmWave antenna.
      • Use a Torx T3 screwdriver to remove the 5.1 mm-long screw securing the mmWave antenna bracket.
      Demander à FixBot
    2. Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the mmWave antenna bracket: étape 27, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the mmWave antenna bracket: étape 27, image 2 de 2
      • Use a pair of tweezers to remove the mmWave antenna bracket.
      Demander à FixBot
    3. Google Pixel 7 Pro Earpiece Speaker Replacement, Disconnect the mmWave antenna cable: étape 28, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Disconnect the mmWave antenna cable: étape 28, image 2 de 2
      • Use a spudger to disconnect the mmWave antenna cable by prying the connector straight up from its socket.
      Demander à FixBot
    4. Google Pixel 7 Pro Earpiece Speaker Replacement, Loosen the mmWave antenna cable: étape 29, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Loosen the mmWave antenna cable: étape 29, image 2 de 2
      • The mmWave antenna cable is held in place by mild adhesive.
      • Slide an opening pick underneath the mmWave antenna cable starting at its bottom end.
      • Use the opening pick to separate the mmWave antenna cable from the motherboard.
      Demander à FixBot
    5. Google Pixel 7 Pro Earpiece Speaker Replacement: étape 30, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement: étape 30, image 2 de 2
      • Repeat the previous procedure and use the opening pick to separate the horizontal part of the mmWave antenna cable from the motherboard.
      Demander à FixBot
    6. Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the mmWave antenna assembly: étape 31, image 1 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the mmWave antenna assembly: étape 31, image 2 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the mmWave antenna assembly: étape 31, image 3 de 3
      • Use a pair of tweezers to lift the mmWave antenna including its cable out of its recess.
      • Remove the mmWave antenna assembly.
      Demander à FixBot
    1. Google Pixel 7 Pro Earpiece Speaker Replacement, Unfasten the rear camera assembly screws: étape 32, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Unfasten the rear camera assembly screws: étape 32, image 2 de 2
      • Use a Torx T3 screwdriver to remove the two 5.1 mm-long screws securing the rear camera assembly.
      Demander à FixBot
    2. Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the spring: étape 33, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the spring: étape 33, image 2 de 2
      • Use a pair of tweezers to remove the spring at the top left corner of the rear camera assembly.
      Demander à FixBot
    3. Google Pixel 7 Pro Earpiece Speaker Replacement, Disconnect the front facing camera: étape 34, image 1 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Disconnect the front facing camera: étape 34, image 2 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement, Disconnect the front facing camera: étape 34, image 3 de 3
      • Use a spudger to disconnect the front facing camera cable by prying the connector straight up from its socket.
      • Fold the cable upwards to free the rear camera assembly.
      • Do not fold the cable sharply or you'll damage the cable.
      Demander à FixBot
    4. Google Pixel 7 Pro Earpiece Speaker Replacement, Disconnect the camera cables: étape 35, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Disconnect the camera cables: étape 35, image 2 de 2
      • Use a spudger to disconnect the telephoto camera cable by prying the connector straight up from its socket.
      Demander à FixBot
    5. Google Pixel 7 Pro Earpiece Speaker Replacement: étape 36, image 1 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement: étape 36, image 2 de 3 Google Pixel 7 Pro Earpiece Speaker Replacement: étape 36, image 3 de 3
      • Use a spudger to disconnect the wide and ultrawide camera cables by prying the connectors straight up from their sockets.
      Demander à FixBot
    6. Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the rear camera assembly: étape 37, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the rear camera assembly: étape 37, image 2 de 2
      • Remove the rear camera assembly.
      • If your replacement camera module has a plastic spacer, be sure to remove it before you install the module.
      • Make sure the lens surface is smudge and dust free before you install the camera assembly.
      Demander à FixBot
    1. Google Pixel 7 Pro Earpiece Speaker Replacement, Unfasten the earpiece speaker screw: étape 38, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Unfasten the earpiece speaker screw: étape 38, image 2 de 2
      • Use a Torx T3 screwdriver to remove the 3.1 mm-long screw securing the earpiece speaker.
      Demander à FixBot
    2. Google Pixel 7 Pro Earpiece Speaker Replacement, Loosen the earpiece speaker adhesive: étape 39, image 1 de 1
      • Apply a heated iOpener to the rear-facing camera glass to loosen the adhesive underneath the earpiece speaker. Apply the iOpener for at least 1 minute.
      Demander à FixBot
    3. Google Pixel 7 Pro Earpiece Speaker Replacement, Pry up the earpiece speaker: étape 40, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Pry up the earpiece speaker: étape 40, image 2 de 2
      • Insert the pointed end of a spudger between the top left corner of the earpiece speaker and the frame.
      • Pry upwards to loosen the earpiece speaker.
      Demander à FixBot
    4. Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the earpiece speaker: étape 41, image 1 de 2 Google Pixel 7 Pro Earpiece Speaker Replacement, Remove the earpiece speaker: étape 41, image 2 de 2
      • Use a pair of tweezers to remove the earpiece speaker.
      Demander à FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 7 Pro answers community for help.
Dominik Schnabelrauch
Membre depuis le 11/23/16
263 413 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
82 057 tutoriels rédigés
3 commentaires de tutoriel
This seems to be a fairly common failure point on these devices, my earpiece died completely. I’ve replaced with a used OEM speaker as well as an aftermarket but neither work upon reassembly and reboot. Not sure what inside the phone itself has gone bad, at least the loud speaker at the bottom is still good I suppose
Austin - Réponse Partager
I have experienced the same problem as another commenter. Just replaced it with aftermarket and still do not have any sound. Not sure. Perhaps some amplification died as when it failed. I heard exactly what happened. Sounded like a static sound from the earpiece and then dead.
Jaden Curley - Réponse Partager
It's the same issue with my Pixel 7 Pro. I replaced the Earpiece Speaker but it didn't resolve the problem.
Alexander D - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 42
30 derniers jours : 186
Total : 8,256
