Aller au contenu principal
HP All-in-one PC Model 24 Motherboard Replacement
Drake Watters
Drake Watters et 2 autres contributeurs
Dernière mise à jour le November 21, 2024
45 minutes - 1 heure
Modérée
Tutoriel réalisé par la communauté
This guide will walk you through the process of replacing the motherboard in the HP All-In-One PC Model 24. Whether you're upgrading or performing maintenance, this step-by-step tutorial will help you safely disassemble, replace, and reassemble your system with ease.
  1. HP All-in-one PC Model 24 Motherboard Replacement, Remove the Front Panel: étape 1, image 1 de 2 HP All-in-one PC Model 24 Motherboard Replacement, Remove the Front Panel: étape 1, image 2 de 2
    • Pry Open the Front Panel: Using the prying tool, gently slide it between the front panel and the main body of the PC at the bottom of the computer. Work your way around the bottom edge, carefully detaching the clips holding the panel.
    • WARNING: Do not put the prying tool between the screen and the panel.
    • Remove the Front Panel: Lift the front panel away from the PC once all clips are detached. Set it aside in a safe place.
    • Power off the PC: Ensure that the PC is turned off and unplugged from the power source. Press the power button once to decharge the computer fully.
  2. HP All-in-one PC Model 24 Motherboard Replacement, Remove the Bottom Panel: étape 2, image 1 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Remove the Bottom Panel: étape 2, image 2 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Remove the Bottom Panel: étape 2, image 3 de 3
    • Turn the PC Around: Place the PC screen-side down on a soft surface to avoid scratching the screen.
    • Pry Open the Bottom Panel: Gently pry open the bottom panel using the prying tool. Work your way around the panel to detach it from the frame.
  3. HP All-in-one PC Model 24 Motherboard Replacement, Unscrew and Remove Front Panel's Screws: étape 3, image 1 de 2 HP All-in-one PC Model 24 Motherboard Replacement, Unscrew and Remove Front Panel's Screws: étape 3, image 2 de 2
    • Unscrew the Front Panel Screws: Use a screwdriver to carefully remove the screws securing the front panel. Keep these screws in a safe place.
    • Note: A magnetic head screwdriver comes in handy here, because some of the screws are in hard to reach places.
  4. HP All-in-one PC Model 24 Motherboard Replacement, Unscrew and Remove the Stand: étape 4, image 1 de 2 HP All-in-one PC Model 24 Motherboard Replacement, Unscrew and Remove the Stand: étape 4, image 2 de 2
    • Locate the Stand Screws: Turn the PC over so that the back is facing up.
    • Unscrew the Stand: Use the screwdriver to remove the screws securing the stand.
    • Remove the Stand: Once the screws are removed, carefully detached the stand from the PC (should be able to pull up and out).
    • Note: The screws can either be removed from the stand or left on the stand. Just be sure to keep them in a safe location to avoid losing them during the process.
  5. HP All-in-one PC Model 24 Motherboard Replacement, Undo the Clips for the Screen and Remove it: étape 5, image 1 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Undo the Clips for the Screen and Remove it: étape 5, image 2 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Undo the Clips for the Screen and Remove it: étape 5, image 3 de 3
    • Release the Clips: Using a plastic prying tool, gently slide it between the screen and the frame. Work your way around the edges, carefully releasing the clips.
    • Power Button Board: Make sure not to damage this part.
    • Note: It is easier to work from the bottom left side and then clockwise around, because the power button board is on the bottom right side. This is what is shown in the picture.
    • WARNING: Take care not to apply excessive force, as this could crack the screen or damage the clips.
    • Life the Screen: Once all the clips have been undone, gently lift the screen away from the frame.
    • Note: It may be helpful to support the screen from both sides to prevent bending or damaging it.
    • WARNING: When lifting the screen, be aware that there are wires and tape connected to it. Carefully lift the screen and place it right next to the PC body to avoid pulling any wiring. Take extra care not to stretch or disconnect any cables.
  6. HP All-in-one PC Model 24 Motherboard Replacement, Removing the Ribbon Cable from the Screen: étape 6, image 1 de 2 HP All-in-one PC Model 24 Motherboard Replacement, Removing the Ribbon Cable from the Screen: étape 6, image 2 de 2
    • Disconnect the Ribbon Cable: Gently lift the small locking mechanism or tab that secures the ribbon cable.
    • Note: This is often a ZIF (Zero Insertion Force) connector, which can be carefully pulled up to release the cable.
    • WARNING: Be very gentle when handling the ribbon cable, as it can be fragile and can tear if too much force is applied.
    • Carefully remove the Ribbon Cable: Once the tab is lifted, gently pull the ribbon cable out of its connector.
    • Note: Take care not to pull on the cable too harshly, as it may be connected to other parts. Also, make sure it is not bent or damaged during the process.
    • Note If your fingernails cannot reach the connector, see step 13 for an alternative method.
  7. HP All-in-one PC Model 24 Motherboard Replacement, Removing the Display Cables: étape 7, image 1 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the Display Cables: étape 7, image 2 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the Display Cables: étape 7, image 3 de 3
    • Disconnect the Cables: Disconnect each display cable from its connector on the motherboard. Do this by pulling on the cables very close to the connector perpendicularly to the board. Pulling directly up prevents any damage to the plug.
    • Take Care When Removing: Handle the cables carefully. Do not pull on the cables with excessive force to avoid damage. Ensure that they are not bent or damaged during the disassembly process.
  8. HP All-in-one PC Model 24 Motherboard Replacement, Removing the Storage: étape 8, image 1 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the Storage: étape 8, image 2 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the Storage: étape 8, image 3 de 3
    • Locate the Storage Drive
    • Unscrew the Storage: Use a screwdriver to remove any screws securing the storage drive.
    • Very Small Screw: This screw requires the precision screwdriver.
    • Remove the Storage Drive: Once the screws are removed, remove the drive from the compartment. Do this by pulling directly away from the connector.
    • WARNING: Do not pull with excessive force. The drive should come out easily.
    • Note: Place the storage drive in a safe location to prevent any static discharge or physical damage.
  9. HP All-in-one PC Model 24 Motherboard Replacement, Removing the Motherboard's Battery: étape 9, image 1 de 2 HP All-in-one PC Model 24 Motherboard Replacement, Removing the Motherboard's Battery: étape 9, image 2 de 2
    • Identify the Battery Holder: Look for the small clip or latch that holds the battery in place. This may be a metal latch.
    • Release the Battery: Using the prying tool or your fingers, gently press the clip that secures the battery.
    • Remove the Battery: Once the clip is released, lift the battery out of its holder.
    • Note: Take note of the orientation of the battery so you can replace it correctly later.
  10. HP All-in-one PC Model 24 Motherboard Replacement, Removing the CPU Cooling Fan: étape 10, image 1 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the CPU Cooling Fan: étape 10, image 2 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the CPU Cooling Fan: étape 10, image 3 de 3
    • Disconnect the Fan's Power Cable: Locate the fan's power cable connected to the motherboard. Gently unplug the cable by pulling on the wire very close to the connector perpendicular to the board.
    • Unscrew the Fan: Use a screwdriver to remove the screws that secure the cooling fan in place. There are only three screws.
    • Note: Keep the screws in a safe place for reassembly.
    • Remove the Fan: Lift the cooling fan away from the CPU and motherboard.
    • Cooling bar system: Do not remove this, yet.
    • WARNING: The device directly behind the fan is the cooling bar system. This is attached to the CPU on the motherboard. Make sure not to damage the system.
  11. HP All-in-one PC Model 24 Motherboard Replacement, Removing the Speakers: étape 11, image 1 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the Speakers: étape 11, image 2 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the Speakers: étape 11, image 3 de 3
    • Locate the Speakers: There should be the left and right speakers.
    • Disconnect the Speaker Cables: Gently disconnect the cables by pulling the wires directly above the plugs perpendicular to the board.
    • Remove the Speakers: Carefully lift the speakers out of their compartments. To lift them they have to be pushed down and out of the locking studs. Be careful not to lose the rubber gaskets that go around the locking studs.
  12. HP All-in-one PC Model 24 Motherboard Replacement, Unplugging the Camera: étape 12, image 1 de 2 HP All-in-one PC Model 24 Motherboard Replacement, Unplugging the Camera: étape 12, image 2 de 2
    • Disconnect the Cable: Gently unplug the camera's cable from its connector on the motherboard by pulling on the wire perpendicular to the board.
  13. HP All-in-one PC Model 24 Motherboard Replacement, Removing the Ribbon Cable from the Power Button: étape 13, image 1 de 2 HP All-in-one PC Model 24 Motherboard Replacement, Removing the Ribbon Cable from the Power Button: étape 13, image 2 de 2
    • Release the Cable's Connector: Carefully release the ribbon cable from its connector on the motherboard. The connector has a latch, gently lift it up to release the cable. The same way as in step 6.
    • Disconnect the Ribbon Cable: Once the latch is released, gently pull the ribbon cable out its connector.
    • Note: Be sure not to pull on the cable too forcefully to avoid damaging the cable or the connector.
  14. HP All-in-one PC Model 24 Motherboard Replacement, Removing the Power Button Board: étape 14, image 1 de 1
    • Optional: This step is optional and not necessary for replacing the motherboard. However, if you want to replace or check this part out, you can remove it.
    • Unscrew the Power Button: Use a screwdriver to remove the screws holding the button in place. Keep the screws in a safe location for reassembly.
    • Gently Detach the Power Button: Once the screws are removed, carefully detach the power button from its mounting position. Make sure to remove the ribbon cable carefully so it is not damaged.
  15. HP All-in-one PC Model 24 Motherboard Replacement, Removing the WiFi card: étape 15, image 1 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the WiFi card: étape 15, image 2 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the WiFi card: étape 15, image 3 de 3
    • Locate the WiFi card
    • Unscrew the WiFi card: The WiFi card is secured with one screw. Use the precision screwdriver to remove the screw holding the WiFi card in place. Keep the screw in a safe location.
    • Remove the WiFi Card: Once the screw is removed, gently pull the WiFi card directly away from the PCIs slot. Be careful not to apply excessive force, as the card can be fragile.
    • WARNING: Do not apply excessive force to the card. The card should come out very easily.
  16. HP All-in-one PC Model 24 Motherboard Replacement, Unplugging the Disc Drive: étape 16, image 1 de 2 HP All-in-one PC Model 24 Motherboard Replacement, Unplugging the Disc Drive: étape 16, image 2 de 2
    • Disconnect the Disc Drive: Gently unplug the cable. Take care to pull on the ribbon above the connector, not the wire or the connector, to avoid damaging the cable.
  17. HP All-in-one PC Model 24 Motherboard Replacement, Removing the Motherboard (Cooling Rod Included): étape 17, image 1 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the Motherboard (Cooling Rod Included): étape 17, image 2 de 3 HP All-in-one PC Model 24 Motherboard Replacement, Removing the Motherboard (Cooling Rod Included): étape 17, image 3 de 3
    • Unscrew the Motherboard: Use a screwdriver to remove the screws around the edges of the motherboard.
    • Unscrew the Cooling Bar: Loosen the screw. This screw should not come out.
    • Removing the Motherboard: Lift the motherboard and cooling rod together out of the PC.
    • Note: Be sure to keep these screws in a safe location for reassembly.
To put in the new motherboard follow the same steps in reverse with the new motherboard.
Drake Watters
Membre depuis le 11/17/24
285 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 32
30 derniers jours : 129
Total : 635
