Aller au contenu principal
HP Compaq 2510p RAM Replacement
Nathan Pereira
Nathan Pereira et 2 autres contributeurs
Dernière mise à jour le December 26, 2016
10 minutes
Facile
This guide requires only two screws to be removed with Phillips head screwdriver. Once the panel is removed, the ram can easily be pulled out.
Ce dont vous avez besoin
Outils
  1. HP Compaq 2510p RAM Replacement, RAM: étape 1, image 1 de 1
    • Flip the device over so the back panel is facing upwards. Locate the RAM plate cover towards the left side of the laptop. There will be two screws located on the panel.
  2. HP Compaq 2510p RAM Replacement: étape 2, image 1 de 1
    • Remove both screws holding the RAM cover plate in place using your Phillips Screwdriver.
  3. HP Compaq 2510p RAM Replacement: étape 3, image 1 de 1
    • Remove the cover plate by lifting upwards once screws are removed.
  4. HP Compaq 2510p RAM Replacement: étape 4, image 1 de 1
    • Carefully release the pins that are securing the RAM in place by pushing in a outward motion, away from the RAM.
    • Be sure to ground yourself before touching the RAM.
    • Be gentle when releasing the pins.
  5. HP Compaq 2510p RAM Replacement: étape 5, image 1 de 1
    • Remove the old RAM by lifting it upwards, then pulling.
3 autres ont terminé cette réparation.
Nathan Pereira
Membre depuis le 10/26/16
81 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Membre de l'équipe UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 13
Total : 893
