Aller au contenu principal
HP Compaq 6910p RAM Replacement
Tyler Fricks
Tyler Fricks et 2 autres contributeurs
Dernière mise à jour le December 24, 2015
5 minutes
Facile
In this guide, we will illustrate how to remove and replace the RAM card of this device. Thumbs and a Phillips screw driver are required to replace this item.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. HP Compaq 6910p RAM Replacement, RAM: étape 1, image 1 de 2 HP Compaq 6910p RAM Replacement, RAM: étape 1, image 2 de 2
    • Loosen the 1.5 cm Phillips #1 screw.
    • Lift up the cover.
  2. HP Compaq 6910p RAM Replacement: étape 2, image 1 de 3 HP Compaq 6910p RAM Replacement: étape 2, image 2 de 3 HP Compaq 6910p RAM Replacement: étape 2, image 3 de 3
    • Locate the release latches marked in red.
    • Press down on the release latches simultaneously to release the RAM.
    • Remove the RAM.
2 autres ont terminé cette réparation.
Tyler Fricks
Membre depuis le 10/22/15
528 Réputation
5 tutoriels rédigés
Équipe
Montana Tech, Team 3-2, Shirk Fall 2015 Membre de l'équipe Montana Tech, Team 3-2, Shirk Fall 2015
MTUM-SHIRK-F15S3G2
5 membres
5 tutoriels rédigés
5 commentaires
Can The RAM in this machine run with anything more then just 2GB's? I am just wondering.
Marshall WahlstromHelgren - Réponse
This laptop can run even 8gb ram (2x4gb), the second slot is under the keyboard.
Zar' Roc - Réponse
How many gb of ram should be put in the back….a 4gb  or can an 8gb ram be inserted in the back so you can not have to put any more under the keyboard if you wanted to just upgrade to 8 gb at one time or 4gb at one time and not ever have to buy 2gb, 4gb or 8gb.  answer me at natefoster@bellsouth.net.  I have in my HP6910p  a 2gb ram and a small 60 harddrive and the computer seems to be slow.  Do I need to increase the ram or the harddrive  or both.  Help me with this.  I am waiting too long to start the computer up.  It is a good computer. What should I do to get more speed.
natefoster -
where´s the second slot located?
Patrick Wirth - Réponse
It is under the keyboard. There a few youtube videos showing how to remove the keyboard and get to the second slot.
Dynasty -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 14
Total : 3,662
