Aller au contenu principal
HP Compaq Presario CQ56-110US CD Drive Replacement
Iyonna L. Tynes
Iyonna L. Tynes et 2 autres contributeurs
Dernière mise à jour le May 25, 2017
5 - 7 minutes
Modérée
This guide will detail the steps of replacing a faulty CD Drive.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. HP Compaq Presario CQ56-110US CD Drive Replacement, CD Drive: étape 1, image 1 de 2 HP Compaq Presario CQ56-110US CD Drive Replacement, CD Drive: étape 1, image 2 de 2
    • Loosen the two indicated screws on the panel using a Phillips screwdriver with a PH1 head size.
    • The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool.
  2. HP Compaq Presario CQ56-110US CD Drive Replacement: étape 2, image 1 de 1
    • Use the screwdriver to unscrew the four 5mm screws holding down the hard drive.
  3. HP Compaq Presario CQ56-110US CD Drive Replacement: étape 3, image 1 de 2 HP Compaq Presario CQ56-110US CD Drive Replacement: étape 3, image 2 de 2
    • Use plastic opening tools to lift up the hard drive. Set aside the hard drive without disconnecting the wire.
  4. HP Compaq Presario CQ56-110US CD Drive Replacement: étape 4, image 1 de 1
    • Use a Phillips screwdriver with a PH0 head type to unscrew the indicated 5.5mm screw.
  5. HP Compaq Presario CQ56-110US CD Drive Replacement: étape 5, image 1 de 1
    • Use plastic opening tools to pry open the CD Drive.
  6. HP Compaq Presario CQ56-110US CD Drive Replacement: étape 6, image 1 de 1
    • Use your hands to pull the CD drive out and remove it from the laptop.
Iyonna L. Tynes
Membre depuis le 02/15/17
446 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 8-4, Eyestone Spring 2017 Membre de l'équipe USF Tampa, Team 8-4, Eyestone Spring 2017
USFT-EYESTONE-S17S8G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 6
Total : 860
