Aller au contenu principal
HP Compaq Presario CQ56-110US Disassembly
Macix26
Macix26 et un autre contributeur
Dernière mise à jour le December 9, 2020
25 - 50 minutes
Modérée
Tutoriel réalisé par la communauté
Complete Disassembly of The Laptop excluding Laptop Display
Ce dont vous avez besoin
Outils
Afficher plus…
  1. HP Compaq Presario CQ56-110US Disassembly, Removing Battery: étape 1, image 1 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing Battery: étape 1, image 2 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing Battery: étape 1, image 3 de 3
    • Remove Battery by sliding the tab
  2. HP Compaq Presario CQ56-110US Disassembly, Removing Ram Cover: étape 2, image 1 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing Ram Cover: étape 2, image 2 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing Ram Cover: étape 2, image 3 de 3
    • Remove the 3 screws from the Ram Cover and lift up the cover
  3. HP Compaq Presario CQ56-110US Disassembly, Removing Ram Sticks and Wifi Card: étape 3, image 1 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing Ram Sticks and Wifi Card: étape 3, image 2 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing Ram Sticks and Wifi Card: étape 3, image 3 de 3
    • Remove Ram Stick by pulling the tabs to it side
    • Remove the to remove the Wifi Card and remove its antenna wires
  4. HP Compaq Presario CQ56-110US Disassembly, Removing Hard Drive Cover: étape 4, image 1 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing Hard Drive Cover: étape 4, image 2 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing Hard Drive Cover: étape 4, image 3 de 3
    • Remove 2 Screw from the Hard Drive Cover and lift up the cover
  5. HP Compaq Presario CQ56-110US Disassembly, Removing the Hard Drive: étape 5, image 1 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing the Hard Drive: étape 5, image 2 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing the Hard Drive: étape 5, image 3 de 3
    • Remove the 3 screws from the Hard Drive
    • Remove the SATA Cable from the Hard Drive and Motherboard
  6. HP Compaq Presario CQ56-110US Disassembly, Removing Screws: étape 6, image 1 de 1
    • Remove 10 screws from the laptop
    • Remove 3 2.5 x 6.5 screws from the laptop
    • Remove 3 2.5 x 5 screws from the laptop
    • Remove 4 2.5 x 3 screws from the laptop
    • *The Photo looks incomplete because it exceeded the crop limit
  7. HP Compaq Presario CQ56-110US Disassembly, Removing the Keyboard: étape 7, image 1 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing the Keyboard: étape 7, image 2 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing the Keyboard: étape 7, image 3 de 3
    • Put Your Hands on the Top Corners and Put some little pressure
    • Be careful that there is a ribbon cable under there and make sure that it is removed
  8. HP Compaq Presario CQ56-110US Disassembly, Removing Top Cover: étape 8, image 1 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing Top Cover: étape 8, image 2 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing Top Cover: étape 8, image 3 de 3
    • Remove the Ribbon Cables and Wires from the Motherboard and use a pick to remove the top cover
    • Remove 1 screw and lift up the top cover
  9. HP Compaq Presario CQ56-110US Disassembly, Removing the CD Drive: étape 9, image 1 de 2 HP Compaq Presario CQ56-110US Disassembly, Removing the CD Drive: étape 9, image 2 de 2
    • Remove the CD Drive by Pushing or Pulling to the outside
  10. HP Compaq Presario CQ56-110US Disassembly, Removing the Display Cable: étape 10, image 1 de 2 HP Compaq Presario CQ56-110US Disassembly, Removing the Display Cable: étape 10, image 2 de 2
    • Remove the 3 Display Cables and a USB Port Ribbon Cable
  11. HP Compaq Presario CQ56-110US Disassembly, Remove Motherboard Screws: étape 11, image 1 de 2 HP Compaq Presario CQ56-110US Disassembly, Remove Motherboard Screws: étape 11, image 2 de 2
    • Remove 2 Screws from the Motherboard
  12. HP Compaq Presario CQ56-110US Disassembly, Removing the Motherboard: étape 12, image 1 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing the Motherboard: étape 12, image 2 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing the Motherboard: étape 12, image 3 de 3
    • Remove the Power Cable and pull the motherboard to the right
  13. HP Compaq Presario CQ56-110US Disassembly, Removing the CPU Heatsink: étape 13, image 1 de 2 HP Compaq Presario CQ56-110US Disassembly, Removing the CPU Heatsink: étape 13, image 2 de 2
    • Remove the Six Screws from the Heatsink
    • Remove the Cable of the fan
  14. HP Compaq Presario CQ56-110US Disassembly, Removing the CPU: étape 14, image 1 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing the CPU: étape 14, image 2 de 3 HP Compaq Presario CQ56-110US Disassembly, Removing the CPU: étape 14, image 3 de 3
    • Use Something Flat Tipped like a Flat tip screw driver
    • Be Careful with removing the CPU because it has fragile pins under it, remove it by wiggling it back and forth
  15. HP Compaq Presario CQ56-110US Disassembly, And We're Done.....: étape 15, image 1 de 2 HP Compaq Presario CQ56-110US Disassembly, And We're Done.....: étape 15, image 2 de 2
    • Laptop Dissasembly Complete, Here is Everything except for the Case and Display
To reassemble your device, follow these instructions in reverse order. This can be useful for a CPU Upgrade
6 autres ont terminé cette réparation.
Macix26
Membre depuis le 12/11/19
455 Réputation
1 tutoriel rédigé
Un commentaire
Thank you so much . I learned to unlock the device by following the illustrations
hussein abbas - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 45
Total : 2,128
