Aller au contenu principal
HP Compaq Pro 6300 RAM Replacement
907fixer
907fixer et un autre contributeur
Dernière mise à jour le July 30, 2024
5 minutes
Facile
Tutoriel réalisé par la communauté
A guide to upgrading the RAM in the HP Compaq Pro 6300.
  1. HP Compaq Pro 6300 RAM Replacement, RAM: étape 1, image 1 de 2 HP Compaq Pro 6300 RAM Replacement, RAM: étape 1, image 2 de 2
    • Grab the handle and pull, then lift the cover off.
    • Make sure the power cord and other connectors are disconnected before beginning. You should also drain any residual power by pushing the power button after the computer is unplugged.
  2. HP Compaq Pro 6300 RAM Replacement: étape 2, image 1 de 3 HP Compaq Pro 6300 RAM Replacement: étape 2, image 2 de 3 HP Compaq Pro 6300 RAM Replacement: étape 2, image 3 de 3
    • Grab the tab and pull up the DVD drive to access the RAM.
  3. HP Compaq Pro 6300 RAM Replacement: étape 3, image 1 de 3 HP Compaq Pro 6300 RAM Replacement: étape 3, image 2 de 3 HP Compaq Pro 6300 RAM Replacement: étape 3, image 3 de 3
    • Put your thumbs on the two tabs surrounding the RAM sticks and push down.
    • This requires a lot of pressure, so don't be afraid to give it some force.
    • If you need more room, you can unplug the SATA cables that connect the hard drive and DVD drive to the computer- just make sure you plug them back in when you finish.
    • Pull the module out by the top or the sides. Take care not to touch the delicate pins at the bottom and the chips on the surface.
    • You may have a different number of modules depending on your configuration. If you have one or more empty slot, you can skip to step 4.
  4. HP Compaq Pro 6300 RAM Replacement: étape 4, image 1 de 3 HP Compaq Pro 6300 RAM Replacement: étape 4, image 2 de 3 HP Compaq Pro 6300 RAM Replacement: étape 4, image 3 de 3
    • Insert the new module, lining the notch on the module with the notch in the slot.
    • Push down on the module until you hear both tabs lock into the notches.
    • This requires a great deal of pressure, so after you've checked that the notch on the bottom is lined up correctly, don't be afraid to push hard.
907fixer
Membre depuis le 05/23/23
558 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 20
Total : 200
