Aller au contenu principal
HP Envy 23-d060qd TouchSmart RAM Replacement
Zachary Dicks
Zachary Dicks et 7 autres contributeurs
Dernière mise à jour le December 28, 2017
5 - 10 minutes
Facile
Tutoriel étudiant vedette
My computer really stalls when I have more than one program open at once. What can I do so that I can watch Netflix, listen to Spotify, and work on homework all at once? I'll just replace the RAM, it will only take 5 minutes away from Netflix.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. HP Envy 23-d060qd TouchSmart RAM Replacement, Back Panel: étape 1, image 1 de 1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart RAM Replacement: étape 2, image 1 de 1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart RAM Replacement: étape 3, image 1 de 1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart RAM Replacement, RAM: étape 4, image 1 de 2 HP Envy 23-d060qd TouchSmart RAM Replacement, RAM: étape 4, image 2 de 2
    • Pop off the easy-access cover to get into the RAM module.
  5. HP Envy 23-d060qd TouchSmart RAM Replacement: étape 5, image 1 de 2 HP Envy 23-d060qd TouchSmart RAM Replacement: étape 5, image 2 de 2
    • Push out the four clips that hold the RAM modules to the side.
    • The RAM modules will pop open after you unclick all four clips.
  6. HP Envy 23-d060qd TouchSmart RAM Replacement: étape 6, image 1 de 1
    • Pull out each module.
    • Replace RAM with desired replacement.
    • When substituting your RAM in, make sure to line up the edges with the lines on the RAM compartment so that the RAM is able to fit inside properly.
5 autres ont terminé cette réparation.
Zachary Dicks
Membre depuis le 10/01/15
1 135 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 5-10, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 14
30 derniers jours : 27
Total : 3,383
