HP Pavilion 11-n010dx Ram Replacement
Introduction
Passez à l'étape 1This is a guide to help you replace the Memory (RAM) of your device. In doing this it should help to make your device run faster or stop your device from crashing unpredictably. Be sure the device is turned off and disconnected from all power sources.
Ce dont vous avez besoin
Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
Use the Phillips #0 to remove four 9mm screws.
Use the Phillips #0 to remove seven 6mm screws.
Using your fingernails, pull the tabs on either side of the RAM to release the module from its secured spot.
