HP Pavilion g7-2023cl Upper Case Assembly Replacement
Introduction
Passez à l'étape 1The touchpad/track pad and power button are embedded into the upper case assembly for this device. There are a few reasons to replace the upper case assembly. The upper case may be broken, out of place, the touchpad/track pad no longer work, or the power button is broken. Whatever the reason, this guide will show you how to replace the upper case assembly.
Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
Locate the hard drive cable connector pull tab.
Pinch the pull tab pulling upwards from the motherboard to disconnect the hard drive cable.
Using a Phillips #0 screwdriver, remove the optical drive anchor screw.
Locate the power button cable near the top left corner of the upper case assembly.
Using a spudger, flip up the power button ribbon cable locking tab.
