Aller au contenu principal
HP ZBOOK 15 G5 LCD Replacement
Ved Pitre
Ved Pitre et 2 autres contributeurs
Dernière mise à jour le November 27, 2024
20 - 30 minutes
Modérée
Tutoriel réalisé par la communauté
  1. HP ZBOOK 15 G5 LCD Replacement, Opening the Bottom Panel: étape 1, image 1 de 1
    • Find the bottom panel locking mechanism
    • Move the switch to the right to unlock and slide it in a downwards fashion
  2. HP ZBOOK 15 G5 LCD Replacement, Removing the Battery: étape 2, image 1 de 1
    • Slide the battery latches to the right to loosen the battery
    • Remove the battery and place it to the side
  3. HP ZBOOK 15 G5 LCD Replacement, Removing the Bottom Case: étape 3, image 1 de 1
    • Remove the keyboard screws
    • Remove these screws with a T8 screwdriver
    • Remove these screws with a philips screwdriver
    • Once they are removed, carefully lift up the bottom case
  4. HP ZBOOK 15 G5 LCD Replacement, Removing SSD and LCD Connector Cover: étape 4, image 1 de 1
    • Unscrew SSD screw and slide the SSD out
    • Remove these screws and place the LCD connector cover to the side
    • Disconnect all of the motherboard connectors
  5. HP ZBOOK 15 G5 LCD Replacement, Removing the LCD: étape 5, image 1 de 1
    • Unscrew the 6 LCD screws to the top left and right
    • Once removed, carefully remove the LCD
    • Tip: Remove two screws from each side and then place the laptop on it's side. Unscrew the final two and separate the LCD and Top Case
    • Screw the new LCD in and make sure to connect all of the LCD connectors
    • Screw the bottom case back onto the laptop
    • Connect the battery and put the battery cover back into place
Once the repair had been done. Call the user and let them know their laptop is ready for pick-up
Ved Pitre
Membre depuis le 10/30/19
1 092 Réputation
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 34
30 derniers jours : 130
Total : 7,950
