Aller au contenu principal
HTC One Max Fingerprint Sensor Replacement
Andrey Sklyar
Andrey Sklyar et 6 autres contributeurs
Dernière mise à jour le May 7, 2024
15 minutes
Modérée
In this guide you are going to learn how to replace the fingerprint sensor on the HTC One Max phone.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. HTC One Max Fingerprint Sensor Replacement, Back Case: étape 1, image 1 de 1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
  2. HTC One Max Fingerprint Sensor Replacement: étape 2, image 1 de 2 HTC One Max Fingerprint Sensor Replacement: étape 2, image 2 de 2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
  3. HTC One Max Fingerprint Sensor Replacement: étape 3, image 1 de 1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
  4. HTC One Max Fingerprint Sensor Replacement: étape 4, image 1 de 2 HTC One Max Fingerprint Sensor Replacement: étape 4, image 2 de 2
    • Use the small plastic opening tool to pry between the screen and the rear case.
  5. HTC One Max Fingerprint Sensor Replacement, Fingerprint Sensor: étape 5, image 1 de 2 HTC One Max Fingerprint Sensor Replacement, Fingerprint Sensor: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
Andrey Sklyar
Membre depuis le 09/23/14
452 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 11-3, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 1,307
