Aller au contenu principal
HTC Touch Pro 2 Camera Replacement
Melinda Phan
Melinda Phan et 10 autres contributeurs
Dernière mise à jour le May 7, 2024
4 - 8 minutes
Facile
Étudiant en action
If your HTC Touch Pro 2 Camera isn’t turning on, a possible issue may be with the camera lens. Follow this guide to learn how to replace your HTC Touch Pro 2 Camera. After the lens is replaced the quality of picture should be restored to its original state. This guide requires a T5 screwdriver and some tweezers.
Use caution when replacing the lens if the glass of the lens is shattered to avoid injury.
Ce dont vous avez besoin
Outils
  1. HTC Touch Pro 2 Camera Replacement, Battery: étape 1, image 1 de 3 HTC Touch Pro 2 Camera Replacement, Battery: étape 1, image 2 de 3 HTC Touch Pro 2 Camera Replacement, Battery: étape 1, image 3 de 3
    • Apply pressure and slide upward to remove back cover.
    • Lift the back cover up away from the phone.
  2. HTC Touch Pro 2 Camera Replacement: étape 2, image 1 de 2 HTC Touch Pro 2 Camera Replacement: étape 2, image 2 de 2
    • Lift battery upward on the upper right-hand side to remove it.
    • Check the battery to make sure there's no bent corners
  3. HTC Touch Pro 2 Camera Replacement, Camera: étape 3, image 1 de 2 HTC Touch Pro 2 Camera Replacement, Camera: étape 3, image 2 de 2
    • Remove the four screws from the corners of the phone using a T5 Torx screwdriver.
  4. HTC Touch Pro 2 Camera Replacement: étape 4, image 1 de 3 HTC Touch Pro 2 Camera Replacement: étape 4, image 2 de 3 HTC Touch Pro 2 Camera Replacement: étape 4, image 3 de 3
    • Lift the top segment of the phone frame off.
    • Be cautious with the ribbon on the back of this part.
  5. HTC Touch Pro 2 Camera Replacement: étape 5, image 1 de 2 HTC Touch Pro 2 Camera Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    • Use the tweezers to pull the camera cover up and away from the phone. Repeat for the camera underneath.
Melinda Phan
Membre depuis le 04/17/11
438 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 9-64, Walters Spring 2011 Membre de l'équipe Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 membres
18 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 19
Total : 2,525
