Aller au contenu principal
Hair Dryer Electrical Brushes Replacement
Alejandra Medina
Alejandra Medina et un autre contributeur
Dernière mise à jour le September 14, 2024
25 minutes
Modérée
This guide details how to replace worn-out electrical brushes from a Turbo Power 1500 Professional Blow Dryer Model No. 307 by Turbo Power Inc., Type 001 US-110-125. All you need are a couple new electrical brushes and a Phillips #1 screwdriver.
If you're noticing sparks or quick flashes of light when you use your blow dryer, or if it simply isn't working properly, there's a strong chance that the electrical brushes have reached the end of their lifespan. Make sure to purchase electrical brushes that are compatible with your specific device before beginning.
Make sure the dryer is unplugged before beginning.
  1. Hair Dryer Electrical Brushes Replacement, Electrical Brushes: étape 1, image 1 de 3 Hair Dryer Electrical Brushes Replacement, Electrical Brushes: étape 1, image 2 de 3 Hair Dryer Electrical Brushes Replacement, Electrical Brushes: étape 1, image 3 de 3
    • Make sure to unplug the device before beginning.
    • Rotate the stainless steel filter counterclockwise and pull upwards to remove it.
  2. Hair Dryer Electrical Brushes Replacement: étape 2, image 1 de 2 Hair Dryer Electrical Brushes Replacement: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the two screws securing the back cover.
  3. Hair Dryer Electrical Brushes Replacement: étape 3, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 3, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 3, image 3 de 3
    • Lift off the back cover.
  4. Hair Dryer Electrical Brushes Replacement: étape 4, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 4, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 4, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the two screws securing the dryer motor.
    • Remove the motor from its plastic housing.
  5. Hair Dryer Electrical Brushes Replacement: étape 5, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 5, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 5, image 3 de 3
    • Unscrew the small plastic cap on the side of the motor and lift out the spring.
    • Remove the carbon electrical brush.
    • Repeat for the cap on the other side of the motor.
  6. Hair Dryer Electrical Brushes Replacement: étape 6, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 6, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 6, image 3 de 3
    • Install the new carbon brushes, and screw the caps back on.
    • Make sure the spring beneath the cap is properly positioned before tightening,
  7. Hair Dryer Electrical Brushes Replacement: étape 7, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 7, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 7, image 3 de 3
    • Place the motor back into the housing.
    • Rotate the motor clockwise to screw it into place.
    • Refasten the two motor screws using a Phillips #1 screwdriver.
  8. Hair Dryer Electrical Brushes Replacement: étape 8, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 8, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 8, image 3 de 3
    • Place the white wires coming off the motor back in the slots.
    • Place the diode in the slots.
  9. Hair Dryer Electrical Brushes Replacement: étape 9, image 1 de 2 Hair Dryer Electrical Brushes Replacement: étape 9, image 2 de 2
    • Set the power cord back in its slot.
  10. Hair Dryer Electrical Brushes Replacement: étape 10, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 10, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 10, image 3 de 3
    • Reinstall the back cover.
  11. Hair Dryer Electrical Brushes Replacement: étape 11, image 1 de 3 Hair Dryer Electrical Brushes Replacement: étape 11, image 2 de 3 Hair Dryer Electrical Brushes Replacement: étape 11, image 3 de 3
    • Place the two screws back in place and tighten them with a Phillips #1 screwdriver.
Enjoy your functional hair dryer!
Alejandra Medina
Membre depuis le 03/18/22
193 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 21
30 derniers jours : 52
Total : 1,428
