Aller au contenu principal
Health o Meter HDR743  Power Supply Replacement
Dennis White Jr
Dennis White Jr et 8 autres contributeurs
Dernière mise à jour le April 11, 2023
Aucune estimation
Modérée
A besoin de meilleures images
Étapes manquantes
Meilleure introduction
Détails manquants
Ce dont vous avez besoin
Outils
  1. Health o Meter HDR743  Power Supply Replacement, Power Supply: étape 1, image 1 de 1
    • Connect a voltmeter at the power supply’s connection to the circuit board and the power supply.
    • If the the voltage at the power supply is incorrect, the power supply should be replaced.
  2. Health o Meter HDR743  Power Supply Replacement: étape 2, image 1 de 1
    • Use wire strippers to cut the wired connection to the power supply.
    • If the wires need replacing, you will need to use a soldering iron and remove the connections at the board.
  3. Health o Meter HDR743  Power Supply Replacement: étape 3, image 1 de 1
    • Use the wire strippers to cut off the rubber ends of the power supply wires.
    • Use a soldering iron and solder to fuse the connections between the two wires.
  4. Health o Meter HDR743  Power Supply Replacement: étape 4, image 1 de 2 Health o Meter HDR743  Power Supply Replacement: étape 4, image 2 de 2
    • Test the power supply once the wires have been reconnected.
    • If the Health o Meter still has power issues, check the connections between the new power supply and the board.
    • If no issues are found, the circuit board may need to be replaced.
Dennis White Jr
Membre depuis le 04/02/18
217 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 173
