Aller au contenu principal
Heyday Wireless Speaker 8125 Grille Replacement
Ryan Butler
Ryan Butler et 2 autres contributeurs
Dernière mise à jour le October 15, 2024
1 - 5 minutes
Facile
This guide will show you how to remove the Heyday Wireless Speaker 8125 grille. You must remove the grille in order to access the inner components of this device so it's a requirement for all repair guides. The grilled protects the inside of the speaker while allowing the components to get air.
Before beginning this repair, power off the device and disconnect it from the charger.
Ce dont vous avez besoin
Outils
  • Small Plastic Spudger
  1. Heyday Wireless Speaker 8125 Grille Replacement, Grille: étape 1, image 1 de 3 Heyday Wireless Speaker 8125 Grille Replacement, Grille: étape 1, image 2 de 3 Heyday Wireless Speaker 8125 Grille Replacement, Grille: étape 1, image 3 de 3
    • Orient the speaker so that it is sitting upright.
    • Use your nondominant hand to hold the speaker in place while you firmly push the plastic spudger into the seam between the device wall and the grille.
    • Push down with the plastic spudger and lift the grill until you feel it separate from the speaker.
    • Gently remove it from the top of the device.
Ryan Butler
Membre depuis le 01/18/23
363 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 110
