Aller au contenu principal
HoMedics TotalComfort UHE-CM18 Fan Replacement
Johny
Johny et 2 autres contributeurs
Dernière mise à jour le December 29, 2023
10 minutes
Facile
If your humidifier is making loud noises or is not releasing mist, follow this guide to access the fan. This guide is an easy step-by-step process of how to remove your fan for a simple replacement. For this guide, you will need a Phillips #1 screwdriver head to remove and replace the fan.
Ce dont vous avez besoin
Outils
  1. HoMedics TotalComfort UHE-CM18 Fan Replacement, Fan: étape 1, image 1 de 2 HoMedics TotalComfort UHE-CM18 Fan Replacement, Fan: étape 1, image 2 de 2
    • Lift up the water tank and separate it from the humidifier.
    • Flip the humidifier over to its underside.
  2. HoMedics TotalComfort UHE-CM18 Fan Replacement: étape 2, image 1 de 2 HoMedics TotalComfort UHE-CM18 Fan Replacement: étape 2, image 2 de 2
    • Use the Phillips #1 screwdriver to remove the two 7 mm screws that secure the AC power plug.
    • Remove the AC power plug cover.
  3. HoMedics TotalComfort UHE-CM18 Fan Replacement: étape 3, image 1 de 2 HoMedics TotalComfort UHE-CM18 Fan Replacement: étape 3, image 2 de 2
    • Remove the remaining four 7 mm screws that hold the bottom cover.
    • Remove the bottom cover.
  4. HoMedics TotalComfort UHE-CM18 Fan Replacement: étape 4, image 1 de 3 HoMedics TotalComfort UHE-CM18 Fan Replacement: étape 4, image 2 de 3 HoMedics TotalComfort UHE-CM18 Fan Replacement: étape 4, image 3 de 3
    • Remove the 7 mm screw that secures the metal cover for the fan cable.
    • Remove the metal cover.
  5. HoMedics TotalComfort UHE-CM18 Fan Replacement: étape 5, image 1 de 3 HoMedics TotalComfort UHE-CM18 Fan Replacement: étape 5, image 2 de 3 HoMedics TotalComfort UHE-CM18 Fan Replacement: étape 5, image 3 de 3
    • Disconnect the fan cable from the circuit board by pushing down the center at the end and pulling it out of its socket.
    • Remove the fan.
Johny
Membre depuis le 09/08/23
557 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 120
