Aller au contenu principal
HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement
Johny
Johny et 2 autres contributeurs
Dernière mise à jour le December 29, 2023
10 minutes
Modérée
If your humidifier seems to not be turning on, follow this guide to access the power supply board. This guide is an easy-to-follow process of how to remove your power supply board for a replacement. For this guide, you will use a Phillips #1 screwdriver head to remove and replace your power supply board.
Ce dont vous avez besoin
Outils
  1. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement, Power Supply Board: étape 1, image 1 de 2 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement, Power Supply Board: étape 1, image 2 de 2
    • Lift up the water tank and separate it from the humidifier.
    • Flip the humidifier over to its underside.
  2. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 2, image 1 de 2 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 2, image 2 de 2
    • Use the Phillips #1 screwdriver to remove the two 7 mm screws that secure the AC power plug.
    • Remove the AC power plug cover.
  3. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 3, image 1 de 2 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 3, image 2 de 2
    • Remove the remaining four 7 mm screws that hold the bottom cover.
    • Remove the bottom cover.
  4. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 4, image 1 de 3 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 4, image 2 de 3 HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 4, image 3 de 3
    • Disconnect the two cables with the red and white ends by pushing down the center tab at the end and pulling them out of their sockets.
  5. HoMedics TotalComfort UHE-CM18 Power Supply Board Replacement: étape 5, image 1 de 1
    • Remove the power supply board.
Johny
Membre depuis le 09/08/23
557 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 101
