Aller au contenu principal
Holmes box fan motor replacement
Max Cossalter
Max Cossalter et un autre contributeur
Dernière mise à jour le October 29, 2015
Aucune estimation
Facile
This is a very simple guide that will help you dissasemble and replace the motor of your Holmes box fan, this process is easy and it only requires a screwdriver and a new motor to install.
Ce dont vous avez besoin
Pièces
Outils
  1. Holmes box fan motor replacement, Motor: étape 1, image 1 de 3 Holmes box fan motor replacement, Motor: étape 1, image 2 de 3 Holmes box fan motor replacement, Motor: étape 1, image 3 de 3
    • The first step is to make sure you unplug your fan from the outlet.
    • Make sure you also unplug the power cord from the back of the fan.
  2. Holmes box fan motor replacement: étape 2, image 1 de 2 Holmes box fan motor replacement: étape 2, image 2 de 2
    • Now that your fan is unplugged, lay it flat with the brand label facing upward.
    • Next is to remove the front cover.
    • Remove the six screws from the perimeter of the cover in order to remove the front cover.
  3. Holmes box fan motor replacement: étape 3, image 1 de 2 Holmes box fan motor replacement: étape 3, image 2 de 2
    • Next is the back cover.
    • Flip over the fan so you have access to these six screws.
    • Remove the six screws from the perimeter of the cover in order to remove the back cover.
  4. Holmes box fan motor replacement: étape 4, image 1 de 1
    • Remove these four screws in order to remove the motor and fan blades from the housing.
  5. Holmes box fan motor replacement: étape 5, image 1 de 1
    • The housing should now be able to lift away from the motor and fan blade.
  6. Holmes box fan motor replacement: étape 6, image 1 de 3 Holmes box fan motor replacement: étape 6, image 2 de 3 Holmes box fan motor replacement: étape 6, image 3 de 3
    • The next step is to remove the mounts that held the motor to the housing.
    • Remove these four screws to remove the mounts.
  7. Holmes box fan motor replacement: étape 7, image 1 de 2 Holmes box fan motor replacement: étape 7, image 2 de 2
    • Now you are able to remove the motor from the fan blades.
    • Be careful, if you used your fan recently the motor may be quite hot.
  8. Holmes box fan motor replacement: étape 8, image 1 de 1
    • Now you can insert your new motor and you are done!
6 autres ont terminé cette réparation.
Max Cossalter
Membre depuis le 09/29/15
341 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-4, Green Fall 2015 Membre de l'équipe Cal Poly, Team 15-4, Green Fall 2015
CPSU-GREEN-F15S15G4
4 membres
4 tutoriels rédigés
5 commentaires
Where might one find a replacement motor for a older box fan
Chris Cook - Réponse
Also, I would like to know where to get a replacement motor, as shown in step 4.
Vince Doriean - Réponse
Great guide! Upon reassembling, I noticed that the center of the propeller touches the front grill where it says Holmes. Anyone know if they rub on each other by design?
Zeev - Réponse
My version of the fan came with a similar cord, however the female end had a bump in the center on the end that latches into the fan. Without shaving that piece off, the plug doesn’t detach without taking it apart and prying it out.
applejack_ - Réponse
Also want to know where to find this kind of replacement motor?
Bridget Alice Alonso - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 16
Total : 12,998
