Aller au contenu principal
Homedics UHE-CMP15 Charging Cable Cleaning
Kade Betterton
Kade Betterton et 3 autres contributeurs
Dernière mise à jour le January 2, 2024
2 minutes
Très facile
If the device is not charging, follow this guide to cleaning or replacing the charging cable. You will need a spudger and a spare type-c charging cable on hand.
Ce dont vous avez besoin
Pièces
Outils
  • Spudger
    Spudger
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: étape 1, image 1 de 2 Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: étape 1, image 2 de 2
    • Check the USB port/both ends of the charging cable for dust or grime buildup.
  2. Homedics UHE-CMP15 Charging Cable Cleaning: étape 2, image 1 de 2 Homedics UHE-CMP15 Charging Cable Cleaning: étape 2, image 2 de 2
    • Clear out any buildup carefully with a plastic tool, never metal.
    • Gently rub the plastic tool of choice along the charging port and remove and dust that may have built up over time.
    • Try the charger again, you should see a red LED indicator if the device is charging.
  3. Homedics UHE-CMP15 Charging Cable Cleaning: étape 3, image 1 de 1
    • A red light should appear above the charging port when plugged in, if it does not then the charging cable should be replaced.
    • Purchase a replacement type-c charger or use another charger you already own to test again.
    • If this does not resolve the issue then the battery may be dead, or there is some other issue.
If this guide does not solve your charging problem, check out the battery replacement guide instead.
Kade Betterton
Membre depuis le 10/30/23
267 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-6, Konn Fall 2023 Membre de l'équipe UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 123
