Aller au contenu principal
Homedics UHE-CMP15 Water Replacement
Dylan
Dylan et 2 autres contributeurs
Dernière mise à jour le January 2, 2024
1 minute
Très facile
If the water in your device's container smells bad, follow this guide to replace the water inside the container with clean and fresh water. For this guide you will need some sort of towel or cleaning device to clean the container.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Homedics UHE-CMP15 Water Replacement, Water: étape 1, image 1 de 1
    • Unscrew the container from the lid.
    • Turn the cap counterclockwise and gently remove the lid from the container.
  2. Homedics UHE-CMP15 Water Replacement: étape 2, image 1 de 1
    • Remove the water that is already in the container and dump the old water into safe water disposal area.
    • Dump the old water outside or down the sink.
  3. Homedics UHE-CMP15 Water Replacement: étape 3, image 1 de 1
    • Clean out the container.
    • Use a towel, some soap, and water to clean out the container.
    • You can also use a mix of 50/50 white vinegar and water to clean.
    • Take the damp towel and move it along all off the container and then rinse it out with water.
  4. Homedics UHE-CMP15 Water Replacement: étape 4, image 1 de 1
    • Fill the container with fresh water.
    • Take some room temperature water from the sink and pour it into the clean container.
Dylan
Membre depuis le 10/30/23
337 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-6, Konn Fall 2023 Membre de l'équipe UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 158
