Aller au contenu principal
Honeywell HYF260BV2 Main Board Replacement
Joshua Moreno
Joshua Moreno et un autre contributeur
Dernière mise à jour le January 7, 2025
30 - 50 minutes
Modérée
This guide shows a step-by-step process for removing a broken, old, or non-functional main board for a Honeywell Quietset Tower Fan HYF260BV2 and replacing it with a new one.
Safety Tips:
  • Unplug your fan before doing anything.
  • Wear a mask if your fan is very dusty.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Honeywell HYF260BV2 Main Board Replacement, Main Board: étape 1, image 1 de 2 Honeywell HYF260BV2 Main Board Replacement, Main Board: étape 1, image 2 de 2
    • Unplug your fan and place it on its side.
    • Twist the red plastic piece off from the bottom.
    • Carefully detach the base from the fan to expose the screws located at the bottom of the fan.
  2. Honeywell HYF260BV2 Main Board Replacement: étape 2, image 1 de 3 Honeywell HYF260BV2 Main Board Replacement: étape 2, image 2 de 3 Honeywell HYF260BV2 Main Board Replacement: étape 2, image 3 de 3
    • Use a TORX Security TR15 screwdriver to unscrew the three 12 mm screws near the bottom of the fan.
  3. Honeywell HYF260BV2 Main Board Replacement: étape 3, image 1 de 3 Honeywell HYF260BV2 Main Board Replacement: étape 3, image 2 de 3 Honeywell HYF260BV2 Main Board Replacement: étape 3, image 3 de 3
    • Use a Phillips #1 screwdriver to remove four 12 mm screws on the head of the fan.
  4. Honeywell HYF260BV2 Main Board Replacement: étape 4, image 1 de 3 Honeywell HYF260BV2 Main Board Replacement: étape 4, image 2 de 3 Honeywell HYF260BV2 Main Board Replacement: étape 4, image 3 de 3
    • Use a heavy-duty spudger or opening tool to release the tabs securing the front and back of the fan, then gently pry them apart.
    • Do this gently because you could break the connectors for the back of the fan.
  5. Honeywell HYF260BV2 Main Board Replacement: étape 5, image 1 de 1
    • Pull off the back of the fan and set it aside.
    • Dust the inside of the fan if it is needed.
    • Be careful when dusting and ensure nothing is knocked out of place.
  6. Honeywell HYF260BV2 Main Board Replacement: étape 6, image 1 de 3 Honeywell HYF260BV2 Main Board Replacement: étape 6, image 2 de 3 Honeywell HYF260BV2 Main Board Replacement: étape 6, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws at the head of the fan.
    • Remove the two larger 14 mm Phillips #1 screws located below.
    • Remove the two 10 mm Phillips #1 screws located between the 14 mm screws.
  7. Honeywell HYF260BV2 Main Board Replacement: étape 7, image 1 de 1
    • Pull the gray cover from the fan to reveal the main board.
  8. Honeywell HYF260BV2 Main Board Replacement: étape 8, image 1 de 1
    • Carefully hold the edges of the main board and slowly pull it out.
  9. Honeywell HYF260BV2 Main Board Replacement: étape 9, image 1 de 2 Honeywell HYF260BV2 Main Board Replacement: étape 9, image 2 de 2
    • Unplug the main board.
    • Follow the cables connected to the board to the bottom of the fan.
  10. Honeywell HYF260BV2 Main Board Replacement: étape 10, image 1 de 2 Honeywell HYF260BV2 Main Board Replacement: étape 10, image 2 de 2
    • Unplug the connector to disconnect the bundle of wires.
    • Use scissors to cut the zip tie that secures the wires.
    • Be careful when you cut the zip tie so that you don't accidentally cut the wires.
  11. Honeywell HYF260BV2 Main Board Replacement: étape 11, image 1 de 1
    • Pull the wires up and slide them out of the fan to replace the main board with a new one.
Joshua Moreno
Membre depuis le 10/16/24
193 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 28-7, Watkins Fall 2024 Membre de l'équipe Austin Community College, Team 28-7, Watkins Fall 2024
AUSTINCC-WATKINS-F24S28G7
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 13
Total : 50
