Aller au contenu principal
Hover-1 Nomad LED Headlights Replacement
Samuel Frazee
Samuel Frazee et 3 autres contributeurs
Dernière mise à jour le January 28, 2019
10 - 15 minutes
Facile
If the LED headlights on your Nomad do not light up when the hoverboard is powered on, your headlights may be damaged. Follow this guide to replace the headlights in the Hover-1 Nomad.
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Hover-1 Nomad LED Headlights Replacement, Outer Shell: étape 1, image 1 de 3 Hover-1 Nomad LED Headlights Replacement, Outer Shell: étape 1, image 2 de 3 Hover-1 Nomad LED Headlights Replacement, Outer Shell: étape 1, image 3 de 3
    • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
    • Remove the following twenty screws by rotating the screwdriver counterclockwise:
    • Eight 16.2mm Phillips #2 screws
    • Eight 15mm Phillips #2 screws
    • Four 19.1mm Phillips #2 screws
    • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
    • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
  2. Hover-1 Nomad LED Headlights Replacement: étape 2, image 1 de 3 Hover-1 Nomad LED Headlights Replacement: étape 2, image 2 de 3 Hover-1 Nomad LED Headlights Replacement: étape 2, image 3 de 3
    • Use a nylon spudger to pry the metal handle away from the outer shell.
    • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
    • Lift the hoverboard off the metal handle.
    • Repeat for the handle on the other side of the hoverboard.
  3. Hover-1 Nomad LED Headlights Replacement: étape 3, image 1 de 1
    • Lift the plastic cover on each side up and away from the device.
    • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
  4. Hover-1 Nomad LED Headlights Replacement: étape 4, image 1 de 2 Hover-1 Nomad LED Headlights Replacement: étape 4, image 2 de 2
    • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
    • Charging port wires
    • Speaker assembly wires
    • Power button wires
    • Headlight wires
    • Only the headlight wires need to be disconnected from the other circuit board.
    • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
  5. Hover-1 Nomad LED Headlights Replacement, LED Headlights: étape 5, image 1 de 1
    • Remove the two 13mm Phillips #1 screws by rotating the screwdriver counterclockwise.
    • Repeat on the other side of the hoverboard to remove the other headlight.
  6. Hover-1 Nomad LED Headlights Replacement: étape 6, image 1 de 1
    • Pull the headlight up and off the outer shell.
Samuel Frazee
Membre depuis le 10/08/18
1 015 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team S15-G1, White Fall 2018 Membre de l'équipe Cal Poly, Team S15-G1, White Fall 2018
CPSU-WHITE-F18S15G1
4 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 303
