Aller au contenu principal
Hover-1 Nomad Power Button Replacement
Samuel Frazee
Samuel Frazee et 2 autres contributeurs
Dernière mise à jour le December 5, 2018
10 - 15 minutes
Modérée
If your Nomad does not power on, the power button may be damaged. Follow this guide to replace the power button in the Hover-1 Nomad.
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. Hover-1 Nomad Power Button Replacement, Outer Shell: étape 1, image 1 de 3 Hover-1 Nomad Power Button Replacement, Outer Shell: étape 1, image 2 de 3 Hover-1 Nomad Power Button Replacement, Outer Shell: étape 1, image 3 de 3
    • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
    • Remove the following twenty screws by rotating the screwdriver counterclockwise:
    • Eight 16.2mm Phillips #2 screws
    • Eight 15mm Phillips #2 screws
    • Four 19.1mm Phillips #2 screws
    • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
    • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
  2. Hover-1 Nomad Power Button Replacement: étape 2, image 1 de 3 Hover-1 Nomad Power Button Replacement: étape 2, image 2 de 3 Hover-1 Nomad Power Button Replacement: étape 2, image 3 de 3
    • Use a nylon spudger to pry the metal handle away from the outer shell.
    • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
    • Lift the hoverboard off the metal handle.
    • Repeat for the handle on the other side of the hoverboard.
  3. Hover-1 Nomad Power Button Replacement: étape 3, image 1 de 1
    • Lift the plastic cover on each side up and away from the device.
    • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
  4. Hover-1 Nomad Power Button Replacement: étape 4, image 1 de 2 Hover-1 Nomad Power Button Replacement: étape 4, image 2 de 2
    • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
    • Charging port wires
    • Speaker assembly wires
    • Power button wires
    • Headlight wires
    • Only the headlight wires need to be disconnected from the other circuit board.
    • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
  5. Hover-1 Nomad Power Button Replacement, Power Button: étape 5, image 1 de 2 Hover-1 Nomad Power Button Replacement, Power Button: étape 5, image 2 de 2
    • Peel off the glue around the power button.
    • Unscrew the hexagonal nut around the power button by rotating the nut counterclockwise with a pair of pliers.
  6. Hover-1 Nomad Power Button Replacement: étape 6, image 1 de 1
    • Feed the wire and connector through the removed nut and pull the power button out through the hole in the outer casing.
Samuel Frazee
Membre depuis le 10/08/18
1 015 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team S15-G1, White Fall 2018 Membre de l'équipe Cal Poly, Team S15-G1, White Fall 2018
CPSU-WHITE-F18S15G1
4 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 340
