How To Open A Desktop Hard Drive
Introduction
Passez à l'étape 1Have you ever wanted to open up an old hard drive? Whether it's to permanently delete your data or to better understand how a disk drive works, I'm going to be showing you how to do it yourself. Note: Doing this is not reversible and can damage your hard drive. I am doing this on a junk hard drive, take caution when you do it yourself.
Ce dont vous avez besoin
Use a size 8 Torx screwdriver to remove the front screws. The location and amount may vary depending on your drive, but they are very easy to locate.
There may be a screw hidden under the front sticker, so make sure to peel it off and check before you open it up. Use a spudger to peel off any material in the way of the screw
This is not a reversible process. I am not responsible for any damage done to you or your hard drive while opening it.
6 autres ont terminé cette réparation.
