Aller au contenu principal
How to Assemble Sigrow Air Pro Plus
Sigrow
Sigrow et 2 autres contributeurs
Dernière mise à jour le July 26, 2024
25 minutes
Difficile
Tutoriel réalisé par la communauté
Ce dont vous avez besoin
Outils
Afficher plus…
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. How to Assemble Sigrow Air Pro Plus, Necessary Parts: étape 1, image 1 de 2 How to Assemble Sigrow Air Pro Plus, Necessary Parts: étape 1, image 2 de 2
    • Make sure you have all the necessary parts to assemble the Air Pro.
    • Six plastic parts from left to right, top to bottom are: Case, hat, fan holder, solar panel holder, PCB plate and filter holder.
    • Fan
    • Battery
    • Solar panel
    • PCB
    • CO2 sensor
    • Filter
  2. How to Assemble Sigrow Air Pro Plus, Assemble the hat: étape 2, image 1 de 3 How to Assemble Sigrow Air Pro Plus, Assemble the hat: étape 2, image 2 de 3 How to Assemble Sigrow Air Pro Plus, Assemble the hat: étape 2, image 3 de 3
    • Place the filter with the pink side up into the hat.
    • Insert the filter holder in the hat. Start with one of the short sides, and align the pins on the filter holder with the holes in the hat.
    • Now push the filter holder in all the way.
    • You should hear a *click* when it snaps into place on all sides.
  3. How to Assemble Sigrow Air Pro Plus, Prepare the Solar Panel: étape 3, image 1 de 3 How to Assemble Sigrow Air Pro Plus, Prepare the Solar Panel: étape 3, image 2 de 3 How to Assemble Sigrow Air Pro Plus, Prepare the Solar Panel: étape 3, image 3 de 3
    • Remove the plastic protective film from the solar panel.
    • Slide the solar panel all the way into the solar panel holder.
  4. How to Assemble Sigrow Air Pro Plus, Prepare the Fan Holder: étape 4, image 1 de 3 How to Assemble Sigrow Air Pro Plus, Prepare the Fan Holder: étape 4, image 2 de 3 How to Assemble Sigrow Air Pro Plus, Prepare the Fan Holder: étape 4, image 3 de 3
    • Note the air direction on the fan. The arrow should be pointing up.
    • The wires need to be on the top of the fan and not go through the case on the side.
    • Insert the fan all the way into the fan holder
    • Only press on the four corners of the fan. Do not push in the of the fan.
    • The fan should fit tightly in the fan holder. If the fan moves when shaken, Try a different fan and fan holder combination.
  5. How to Assemble Sigrow Air Pro Plus, Attach Fan Holder to the Case: étape 5, image 1 de 2 How to Assemble Sigrow Air Pro Plus, Attach Fan Holder to the Case: étape 5, image 2 de 2
    • Pull the fan wires through the hole in the bottom of the case.
    • Push the fan holder tightly into the case.
    • The fan holder should fit tightly in the case. If the fan holder moves when shaken, Try a different fan holder and case combination.
  6. How to Assemble Sigrow Air Pro Plus, Insert the solar panel: étape 6, image 1 de 2 How to Assemble Sigrow Air Pro Plus, Insert the solar panel: étape 6, image 2 de 2
    • Find the hole on the side of the case just below the "Sigrow" text.
    • Insert the solar panel cable through this hole.
  7. How to Assemble Sigrow Air Pro Plus, Insert the PCB plate into the case: étape 7, image 1 de 2 How to Assemble Sigrow Air Pro Plus, Insert the PCB plate into the case: étape 7, image 2 de 2
    • The Sigrow logo should be towards you.
    • The rectangular hole should be to the left of the middle.
    • The hole for the fan wires should be to the top right.
    • Pull the solar panel wires through the PCB plate.
    • Push the PCB plate all the way down into the case.
  8. How to Assemble Sigrow Air Pro Plus, Prepare the PCB: étape 8, image 1 de 2 How to Assemble Sigrow Air Pro Plus, Prepare the PCB: étape 8, image 2 de 2
    • Snap off the two thin strips of the PCB on each side.
    • This can be done by hand or with a pair of pliers.
  9. How to Assemble Sigrow Air Pro Plus, Connect the CO2 sensor wires: étape 9, image 1 de 2 How to Assemble Sigrow Air Pro Plus, Connect the CO2 sensor wires: étape 9, image 2 de 2
    • Ensure that the ports of the connectors are open before inserting the wires.
    • Open
    • Closed
    • Attach the wires of the CO2 sensor in the same way as in the photo.
    • Pull on all the wires carefully to make sure they are properly connected and will not release.
  10. How to Assemble Sigrow Air Pro Plus, Attach the CO2 sensor: étape 10, image 1 de 1
    • Twist the CO2 sensor one time so the wires are not lose.
    • The blue and green wire should be on the outside of the PCB.
    • Use a zip tie to secure the CO2 sensor the the top of the PCB.
    • The sensor should not stick out past the PCB.
  11. How to Assemble Sigrow Air Pro Plus, C: étape 11, image 1 de 2 How to Assemble Sigrow Air Pro Plus, C: étape 11, image 2 de 2
    • Connect the fan to the watermellon connector.
    • Connect the solar panel to the watermellon connector.
    • Make sure that the red positive wire is connected to the positive (+) side as seen in the picture.
  12. How to Assemble Sigrow Air Pro Plus: étape 12, image 1 de 3 How to Assemble Sigrow Air Pro Plus: étape 12, image 2 de 3 How to Assemble Sigrow Air Pro Plus: étape 12, image 3 de 3
    • Make a loop of the excess fan wire.
    • Place a small piece of plastic from a filter on the negative side of the battery holder. The negative side is marked with (-) and is on the side towards the solar panels.
    • Insert the battery with the correct orientation into the battery holder.
    • Pay attention that the plus (+) and minus (-) on the battery and on the PCB are on the same side.
  13. How to Assemble Sigrow Air Pro Plus, Secure the Battery: étape 13, image 1 de 2 How to Assemble Sigrow Air Pro Plus, Secure the Battery: étape 13, image 2 de 2
    • Secure the battery with a zip tie.
    • The zip tie is inserted from the front, just below the "Sigrow" text and goes around the battery and through the PCB again.
    • The zip tie is then sequred with another zip tie.
    • Cut off the remaining parts of the zip tie.
  14. How to Assemble Sigrow Air Pro Plus, Insert the PCB: étape 14, image 1 de 3 How to Assemble Sigrow Air Pro Plus, Insert the PCB: étape 14, image 2 de 3 How to Assemble Sigrow Air Pro Plus, Insert the PCB: étape 14, image 3 de 3
    • Slide the PCB into the case.
    • Carefully pull the solar panel wire to make sure that the wire on the outside is long enough.
  15. How to Assemble Sigrow Air Pro Plus, Remove plastic from the solar panels: étape 15, image 1 de 3 How to Assemble Sigrow Air Pro Plus, Remove plastic from the solar panels: étape 15, image 2 de 3 How to Assemble Sigrow Air Pro Plus, Remove plastic from the solar panels: étape 15, image 3 de 3
    • Remove plastic from the solar panels.
  16. How to Assemble Sigrow Air Pro Plus, Final assembly: étape 16, image 1 de 2 How to Assemble Sigrow Air Pro Plus, Final assembly: étape 16, image 2 de 2
    • Put the hat on the case.
    • Make sure that the holes in the side of the hat are on the side with the solar panels.
    • Do not attach the solar panel to the hat.
    • Place ten Air Pro+ sensors back in the box as shown in the picture.
    • INSERT PICTURE OF FULL BOX
Sigrow
Membre depuis le 05/14/20
1 075 Réputation
5 tutoriels rédigés
Équipe
Sigrow Membre de l'équipe Sigrow
Community
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 62
