Aller au contenu principal
How to Assemble Sigrow Soil Pro Mini
Sigrow
Sigrow et 2 autres contributeurs
Dernière mise à jour le August 6, 2024
5 minutes
Facile
Tutoriel réalisé par la communauté
  1. How to Assemble Sigrow Soil Pro Mini, Necessary parts: étape 1, image 1 de 1
    • Make sure you have all the necessary parts to assemble the Soil Pro Mini.
    • Soil sensor
    • Battery
    • PCB
    • Wireless charger
  2. How to Assemble Sigrow Soil Pro Mini, Prepare the wireless charger: étape 2, image 1 de 3 How to Assemble Sigrow Soil Pro Mini, Prepare the wireless charger: étape 2, image 2 de 3 How to Assemble Sigrow Soil Pro Mini, Prepare the wireless charger: étape 2, image 3 de 3
    • Carefully fold the wireless charger just above the words "Wireless Charger".
    • There are two parts inside the wireless charger. The fold is placed inbetween these two parts.
  3. How to Assemble Sigrow Soil Pro Mini, Connect parts to the PCB: étape 3, image 1 de 3 How to Assemble Sigrow Soil Pro Mini, Connect parts to the PCB: étape 3, image 2 de 3 How to Assemble Sigrow Soil Pro Mini, Connect parts to the PCB: étape 3, image 3 de 3
    • The soil sensor, battery and wireless charger all need to be connected to the PCB.
    • Battery
    • Make sure to connect the red wire to the plus (+) side as marked on the PCB. In this photo, the positive side is on the left.
    • Wireless charger
    • Soil sensor
    • When connecting the soil sensor and the PCB, you should hear a *click*.
  4. How to Assemble Sigrow Soil Pro Mini, Insert the PCB into the case: étape 4, image 1 de 3 How to Assemble Sigrow Soil Pro Mini, Insert the PCB into the case: étape 4, image 2 de 3 How to Assemble Sigrow Soil Pro Mini, Insert the PCB into the case: étape 4, image 3 de 3
    • The PCB and the wireless charger are inserted into the deep pocket of the soil sensor.
    • Make sure that the Wireless Charger logo is facing towards the outside of the case.
    • Assembly is easiest when the PCB is inserted at a slight angle.
    • Push the wireless charged in behind the PCB.
    • The PCB and wireless charger should be at the same height, but not inserted all the way.
  5. How to Assemble Sigrow Soil Pro Mini, Insert the battery: étape 5, image 1 de 3 How to Assemble Sigrow Soil Pro Mini, Insert the battery: étape 5, image 2 de 3 How to Assemble Sigrow Soil Pro Mini, Insert the battery: étape 5, image 3 de 3
    • The battery should be placed in front of the PCB. This is easiest when diagonally inserted.
    • The battery wires are in the upper righthand corner.
  6. How to Assemble Sigrow Soil Pro Mini, Complete assembly: étape 6, image 1 de 3 How to Assemble Sigrow Soil Pro Mini, Complete assembly: étape 6, image 2 de 3 How to Assemble Sigrow Soil Pro Mini, Complete assembly: étape 6, image 3 de 3
    • The components can now be pressed in all the way.
    • The PCB must be below the edge of the soil sensor. The wireless charger is allowed to stick out a little bit.
  7. How to Assemble Sigrow Soil Pro Mini, Packaging: étape 7, image 1 de 2 How to Assemble Sigrow Soil Pro Mini, Packaging: étape 7, image 2 de 2
    • Put the assembled Soil Pro Mini back in the bag.
    • Place 20 assembled Soil Pro Minis back in the box.
    • There shoud be two rows of nine sensors in the box. Two sensors can be placed between the rows.
Ligne d'arrivée
Sigrow
Membre depuis le 05/14/20
1 075 Réputation
5 tutoriels rédigés
Équipe
Sigrow Membre de l'équipe Sigrow
Community
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 131
