Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Clean a Mainstays Coffee Maker Water Tube
Ce dont vous avez besoin
  1. How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: étape 1, image 1 de 3 How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: étape 1, image 2 de 3 How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: étape 1, image 3 de 3
    • Open the top of the coffee maker.
    Demander à FixBot
    Ajouter un commentaire
  2. How to Clean a Mainstays Coffee Maker Water Tube: étape 2, image 1 de 2 How to Clean a Mainstays Coffee Maker Water Tube: étape 2, image 2 de 2
    • Use a Phillips screwdriver to remove the four 6 mm screws surrounding the puncturing needle.
    Demander à FixBot
  3. How to Clean a Mainstays Coffee Maker Water Tube: étape 3, image 1 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 3, image 2 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 3, image 3 de 3
    • Press down on the brew chamber release button and remove the backing piece.
    Demander à FixBot
  4. How to Clean a Mainstays Coffee Maker Water Tube: étape 4, image 1 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 4, image 2 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 4, image 3 de 3
    • Disconnect the water tube from where it is connected to the needle.
    Demander à FixBot
  5. How to Clean a Mainstays Coffee Maker Water Tube: étape 5, image 1 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 5, image 2 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 5, image 3 de 3
    • Flip the coffee maker upside down.
    Demander à FixBot
  6. How to Clean a Mainstays Coffee Maker Water Tube: étape 6, image 1 de 2 How to Clean a Mainstays Coffee Maker Water Tube: étape 6, image 2 de 2
    • Use a Phillips screwdriver to remove the four 7 mm screws on the base of the coffee maker.
    Demander à FixBot
  7. How to Clean a Mainstays Coffee Maker Water Tube: étape 7, image 1 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 7, image 2 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 7, image 3 de 3
    • Remove the base.
    Demander à FixBot
  8. How to Clean a Mainstays Coffee Maker Water Tube: étape 8, image 1 de 2 How to Clean a Mainstays Coffee Maker Water Tube: étape 8, image 2 de 2
    • Use an 8" Phillips screwdriver to remove the five internal 14 mm screws from within the coffee maker.
    • Use an 8" Phillips screwdriver to remove the six internal 7 mm screws from within the coffee maker.
    • The second image shows the approximate placement of the screws; you may have to reach inside and move wires to locate and access all eleven screws.
    Demander à FixBot
  9. How to Clean a Mainstays Coffee Maker Water Tube: étape 9, image 1 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 9, image 2 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 9, image 3 de 3
    • Flip the coffee maker right-side up.
    Demander à FixBot
  10. How to Clean a Mainstays Coffee Maker Water Tube: étape 10, image 1 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 10, image 2 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 10, image 3 de 3
    • Pull the disconnected end of the water tube out of the top of the coffee maker.
    Demander à FixBot
  11. How to Clean a Mainstays Coffee Maker Water Tube: étape 11, image 1 de 1
    • Move the top of the coffee maker out of the way so that you can reach into the base.
    • You may wish to put something under the top to support it.
    Demander à FixBot
  12. How to Clean a Mainstays Coffee Maker Water Tube: étape 12, image 1 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 12, image 2 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 12, image 3 de 3
    • Identify where the water tube is connected at the other end.
    • Use pliers or your hand to disconnect it.
    • If you choose to use pliers, take caution not to puncture the tube.
    Demander à FixBot
  13. How to Clean a Mainstays Coffee Maker Water Tube: étape 13, image 1 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 13, image 2 de 3 How to Clean a Mainstays Coffee Maker Water Tube: étape 13, image 3 de 3
    • Locate any blockages in the water tube and use your chosen tool (chenille stick, wooden dowel, toothpick, etc.) to push them out.
    • If the tube looks cloudy, use a chenille stick to break up the buildup.
    Demander à FixBot
  14. How to Clean a Mainstays Coffee Maker Water Tube: étape 14, image 1 de 1
    • Rinse any remaining debris out of the tube.
    • Depending on what tool you chose to use in the previous step, particles from said tool may need to be rinsed out as well.
    Demander à FixBot
Lorelei Kriss
Membre depuis le 01/30/24
269 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 4-9, Andersen Winter 2024 Membre de l'équipe UC Davis, Team 4-9, Andersen Winter 2024
UCD-ANDERSEN-W24S4G9
2 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 39
30 derniers jours : 127
Total : 2,160
