How to Fix A Broken Makeup Compact Without Alcohol
Introduction
Passez à l'étape 1Use this guide to fix your favorite makeup compact. After a compact is dropped on the floor or has gotten old and cracked, this guide can help restore it. With a hot iron and kitchen silverware, you can press your powder back into place in no time.
Before using this guide make sure you're working on a clear surface, free of clutter and safe for the placement of a hot iron. Keep your hands steady while you're using the knife to remove the metal pan from the compact in step 4. Make sure the iron is unplugged and completely cooled before storage.
Ce dont vous avez besoin
Outils
Afficher plus…
Plug In the iron and turn the heat to the highest setting.
