Aller au contenu principal
How to Fix a Bent Intel CPU Socket Pin
Nam
Nam et un autre contributeur
Dernière mise à jour le May 16, 2022
15 - 30 minutes
Facile
This guide will cover how to fix a bent CPU socket pin on your motherboard. This will require a steady hand in order to carefully move the pins, since they are very small and fragile.
The reason for this fix is because motherboards with a bent CPU socket pin have trouble detecting the CPU itself. This fix can also be enable dual-channel, because there were a lot of problems enabling dual-channel memory for their computers.
The only requirements that is needed for this guide a needle, or any needles that is tiny enough to fix the pins (in my guide, I will be using a math compass, since I don’t have access to a needle), a workplace without any hazards such as electricity, and a steady hand.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. How to Fix a Bent Intel CPU Socket Pin, How to Fix a Bent Intel CPU Socket Pin: étape 1, image 1 de 1
    • Make sure you safely removed your motherboard from your computer.
    • Place your motherboard on a table, or on any grounded surface that you are comfortable to work on.
  2. How to Fix a Bent Intel CPU Socket Pin: étape 2, image 1 de 2 How to Fix a Bent Intel CPU Socket Pin: étape 2, image 2 de 2
    • Unplug the CPU power cable connected to the motherboard.
    • Don't pull the CPU Power cable by the wires to avoid damaging them and the CPU power pins.
  3. How to Fix a Bent Intel CPU Socket Pin: étape 3, image 1 de 1
    • Now, if you have an Intel Cooling Fan, turn the four pins on the CPU cooler counterclockwise.
    • Then pull all four pins to remove the CPU cooler off the motherboard.
    • If you have a different cooler, or an aftermarket cooler, read your manual for your other cooler to see how to properly remove the cooler.
  4. How to Fix a Bent Intel CPU Socket Pin: étape 4, image 1 de 2 How to Fix a Bent Intel CPU Socket Pin: étape 4, image 2 de 2
    • Now remove the CPU cooler off your motherboard, and place the cooler aside.
  5. How to Fix a Bent Intel CPU Socket Pin: étape 5, image 1 de 3 How to Fix a Bent Intel CPU Socket Pin: étape 5, image 2 de 3 How to Fix a Bent Intel CPU Socket Pin: étape 5, image 3 de 3
    • Lift the metal clamp in order to remove the CPU itself. To do this particular step, there is a metal tab which you can push with a little force to carefully raise the metal clamp away after loosening the metal tab.
    • Do not be afraid to use a bit of force when moving the metal tab.
  6. How to Fix a Bent Intel CPU Socket Pin: étape 6, image 1 de 2 How to Fix a Bent Intel CPU Socket Pin: étape 6, image 2 de 2
    • With your thumb and middle finger, remove the CPU off the motherboard.
    • (Optional) You can clean your CPU with rubbing alcohol. In this guide, you don't have to.
  7. How to Fix a Bent Intel CPU Socket Pin: étape 7, image 1 de 2 How to Fix a Bent Intel CPU Socket Pin: étape 7, image 2 de 2
    • As you can see, there are a few bent pins in the CPU socket. It it a bit hard to see the pins since they are very tiny. So, you'll need a needle or any tool to fix the pins in the right directions.
    • Use a needle and gently bend the CPU pins in the right direction where the other CPU pins are facing.
    • Carefully move the pins direction where they are meant to face, because the pins are very fragile.
  8. How to Fix a Bent Intel CPU Socket Pin: étape 8, image 1 de 2 How to Fix a Bent Intel CPU Socket Pin: étape 8, image 2 de 2
    • After fixing the pins, gently place your CPU with your thumb and middle finger into the socket.
    • When reinstalling your CPU back onto the motherboard, try not touch the bottom of the CPU.
  9. How to Fix a Bent Intel CPU Socket Pin: étape 9, image 1 de 3 How to Fix a Bent Intel CPU Socket Pin: étape 9, image 2 de 3 How to Fix a Bent Intel CPU Socket Pin: étape 9, image 3 de 3
    • Lock the CPU tray so that the CPU does not fall out of place. You will need a bit of force to push the lock.
  10. How to Fix a Bent Intel CPU Socket Pin: étape 10, image 1 de 3 How to Fix a Bent Intel CPU Socket Pin: étape 10, image 2 de 3 How to Fix a Bent Intel CPU Socket Pin: étape 10, image 3 de 3
    • Reinstall the CPU cooler and replace the four pins turning them clockwise to secure it to the motherboard.
  11. How to Fix a Bent Intel CPU Socket Pin: étape 11, image 1 de 2 How to Fix a Bent Intel CPU Socket Pin: étape 11, image 2 de 2
    • Plug CPU power cable back into the motherboard.
  12. How to Fix a Bent Intel CPU Socket Pin: étape 12, image 1 de 2 How to Fix a Bent Intel CPU Socket Pin: étape 12, image 2 de 2
    • And now you have completed this fix!
    • Now all you need to do is to place the motherboard back into your computer, and test to see if you can boot into the BIOS screen.
    • The guide only shows how to fix the CPU pin sockets. Putting the motherboard back into your computer will take more time.
Overall, this is the only way to fix of having the CPU undetectable from the motherboard, and enabling dual-channel memory. Some people have to RMA (Return Merchandise Authorization) or return their motherboard to their manufacturer, and receiving with a replacement. RMA’s may take time to receive their replacements, depending of the manufacturer.
5 autres ont terminé cette réparation.
Nam
Membre depuis le 01/12/21
340 Réputation
1 tutoriel rédigé
Équipe
York University, Team S2-G13, O'Regan Winter 2021 Membre de l'équipe York University, Team S2-G13, O'Regan Winter 2021
YORK-O'REGAN-W21S2G13
1 membre
2 tutoriels rédigés
1 commentaire de tutoriel
Bad new my pin is gone💀
Lancelot Aviation (Lancelot) - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 71
30 derniers jours : 381
Total : 28,983
