How to Fix a Hole In Wall
Introduction
Passez à l'étape 1Have you ever opened a door too hard and it hit the wall causing a small hole in the wall? This is a problem that so many people have, especially with children in the home. Most modern homes have walls made of a material called drywall. A hole in drywall is very easy to patch. It requires no prior skill or experience. This fix requires inexpensive tools and materials that you may find at a local hardware store or you may even already have some of these items at home. This is a guide on how to patch a small hole in the wall for beginners. This guide will include a complete step by step guide along with all tools and materials that are needed to complete this task.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
Outil utilisé dans cette étape :Tweezers$4.99
Use pliers (or tweezers if the hole is very small) to clean out hole by removing the drywall out of the hole.
5 autres ont terminé cette réparation.
1 commentaire de tutoriel
Oi! como faço reboca que a parede está pintada branca?
