Aller au contenu principal
How to Repair a Burnt Wire for a Light Globe
HarpreetGill
HarpreetGill et un autre contributeur
Dernière mise à jour le September 2, 2020
15 - 25 minutes
Modérée
Outils incorrects
Welcome to this guide! Here is some basic background information required to begin the fix:
Background experience:
While this guide may look intimidating, no background experience is required! All steps here are made to be novice-friendly.
Hazards:
If you are inexperienced with electricity, rubber/leather gloves are recommended as they act as insulators.
Why is this repair needed?:
This repair is needed as it can be a good skill to know for the future. This fix can apply to anything requiring a fix of a wire.
If all these requirements are met, you can begin the guide!
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. How to Repair a Burnt Wire for a Light Globe, How to Repair a Burnt Wire for a Light Globe: étape 1, image 1 de 2 How to Repair a Burnt Wire for a Light Globe, How to Repair a Burnt Wire for a Light Globe: étape 1, image 2 de 2
    • Use a flathead screwdriver to remove the two 3 mm screws from the power adapter.
  2. How to Repair a Burnt Wire for a Light Globe: étape 2, image 1 de 1
    • If needed, clean the power adapter's shell as much as possible.
  3. How to Repair a Burnt Wire for a Light Globe: étape 3, image 1 de 1
    • Use wire cutters to cut the wires to equal lengths.
  4. How to Repair a Burnt Wire for a Light Globe: étape 4, image 1 de 1
    • Use wire strippers to carefully peel the wire cord to expose 2 cm of wire.
  5. How to Repair a Burnt Wire for a Light Globe: étape 5, image 1 de 1
    • Slide the shell back into the wire cord, past the exposed copper wires.
  6. How to Repair a Burnt Wire for a Light Globe: étape 6, image 1 de 3 How to Repair a Burnt Wire for a Light Globe: étape 6, image 2 de 3 How to Repair a Burnt Wire for a Light Globe: étape 6, image 3 de 3
    • Grab the terminal of the power adapter and loosen the 3 mm screws of the terminal if needed.
    • Wrap one exposed copper wire around one loosened 3 mm screw and tighten the screw immediately.
    • Repeat the second bullet point for the second copper wire.
  7. How to Repair a Burnt Wire for a Light Globe: étape 7, image 1 de 2 How to Repair a Burnt Wire for a Light Globe: étape 7, image 2 de 2
    • Push the shell back into the terminal so that the terminal is protected by the shell.
    • Grab the 3 mm screws that were taken out in the first step and re-screw them into the shell.
  8. How to Repair a Burnt Wire for a Light Globe: étape 8, image 1 de 2 How to Repair a Burnt Wire for a Light Globe: étape 8, image 2 de 2
    • Plug in the power adapter into a functioning power outlet.
    • The light globe should now successfully turn on!
Ligne d'arrivée
HarpreetGill
Membre depuis le 05/11/20
157 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G10, O'Regan Summer 2020 Membre de l'équipe York University, Team S1-G10, O'Regan Summer 2020
YORK-O'REGAN-SU20S1G10
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 22
Total : 606
