Aller au contenu principal
How to Replace the Xbox 360 Optical Drive Belt
Angel Lopez
Angel Lopez et 3 autres contributeurs
Dernière mise à jour le October 11, 2024
1 - 2 heures
Modérée
Tutoriel étudiant vedette
The Xbox 360 is an iconic console, but as time passes the disc tray often stops functioning properly. When this happens we lose the ability to play any desired game. This guide demonstrates how to carefully disassemble the Xbox 360, and replace the drive belt inside the optical drive, so you can go back to enjoying those games. Please use the tools gently, so the Xbox 360 won't get scratched and pieces won't tear off.
Don't forget to fully disconnect your Xbox 360 before beginning the guide. Lastly, here is a link for Screwdriver Best Practices that can help.
Bonnes pratiques pour tournevis
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. How to Replace the Xbox 360 Optical Drive Belt, Optical Drive Belt: étape 1, image 1 de 2 How to Replace the Xbox 360 Optical Drive Belt, Optical Drive Belt: étape 1, image 2 de 2
    • Remove the hard drive.
  2. How to Replace the Xbox 360 Optical Drive Belt: étape 2, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 2, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 2, image 3 de 3
    • Use a pry tool to gently remove the faceplate from the Xbox.
  3. How to Replace the Xbox 360 Optical Drive Belt: étape 3, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 3, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 3, image 3 de 3
    • Press down on the three holes as indicated to release the clips securing the base plate.
    • Remove the base plate.
    • Repeat this step on the other side.
  4. How to Replace the Xbox 360 Optical Drive Belt: étape 4, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 4, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 4, image 3 de 3
    • Repeat the previous step to remove the top plate of the Xbox.
  5. How to Replace the Xbox 360 Optical Drive Belt: étape 5, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 5, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 5, image 3 de 3
    • Gently unhook all four clips located on the front of the Xbox.
    • Take care not to break the plastic clips; it may be fragile.
  6. How to Replace the Xbox 360 Optical Drive Belt: étape 6, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 6, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 6, image 3 de 3
    • Use the flathead screwdriver to gently press down on all of the indicated indents.
    • Remove the top casing from the Xbox.
  7. How to Replace the Xbox 360 Optical Drive Belt: étape 7, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 7, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 7, image 3 de 3
    • Use the T3 Torx screwdriver to remove all six screws.
  8. How to Replace the Xbox 360 Optical Drive Belt: étape 8, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 8, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 8, image 3 de 3
    • Carefully flip over the Xbox to the other side.
    • Lift the Xbox casing off.
  9. How to Replace the Xbox 360 Optical Drive Belt: étape 9, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 9, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 9, image 3 de 3
    • Unplug the two connections in the rear of the disk drive.
  10. How to Replace the Xbox 360 Optical Drive Belt: étape 10, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 10, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 10, image 3 de 3
    • Use a flat screwdriver to remove the four screws underneath the disc drive.
    • Flip over the DVD disc drive and remove the casing.
  11. How to Replace the Xbox 360 Optical Drive Belt: étape 11, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 11, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 11, image 3 de 3
    Outil utilisé dans cette étape :
    • Spin the located area with the flathead screwdriver to open up the disc drive.
    • Use tweezers to remove the belt drive.
  12. How to Replace the Xbox 360 Optical Drive Belt: étape 12, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 12, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 12, image 3 de 3
    • Replace with a new drive belt.
5 autres ont terminé cette réparation.
Angel Lopez
Membre depuis le 02/28/23
349 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 60-7, Watkins Spring 2023 Membre de l'équipe Austin Community College, Team 60-7, Watkins Spring 2023
AUSTINCC-WATKINS-S23S60G7
1 membre
3 tutoriels rédigés
3 commentaires de tutoriel
I CANNOT get past step six. No matter how hard I pry, the pieces are not coming apart. I have pressed and twisted my screwdriver so much that it is damaging the plastic around it yet the pieces still stay together. What do I do?
Spencer Fantastic - Réponse
Gotta buy the available 360 opener tool, its dirt cheap on aliexpress. Attempting via a screwdriver will just trash your case and get you nowhere.
Bootleg Joe (Snapman) -
When I get to step 11, there is literally no opening to be able to spin the wheel manually to open it and replace the band. Step 12 shows 2 rectangular openings in the front of the DVD drive, mine is solid plastic with no open gaps. There must be different types of drives used. Right now I cannot get to the belt to replace it. Anyone see this other type of drive? Any thoughts?
Joe Heeney - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 116
30 derniers jours : 370
Total : 7,820
