Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Replace the Xbox 360 Optical Drive Belt
Ce dont vous avez besoin
  1. How to Replace the Xbox 360 Optical Drive Belt, Optical Drive Belt: étape 1, image 1 de 2 How to Replace the Xbox 360 Optical Drive Belt, Optical Drive Belt: étape 1, image 2 de 2
    • Remove the hard drive.
    Demander à FixBot
    Ajouter un commentaire
  2. How to Replace the Xbox 360 Optical Drive Belt: étape 2, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 2, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 2, image 3 de 3
    • Use a pry tool to gently remove the faceplate from the Xbox.
    Demander à FixBot
  3. How to Replace the Xbox 360 Optical Drive Belt: étape 3, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 3, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 3, image 3 de 3
    • Press down on the three holes as indicated to release the clips securing the base plate.
    • Remove the base plate.
    • Repeat this step on the other side.
    Demander à FixBot
  4. How to Replace the Xbox 360 Optical Drive Belt: étape 4, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 4, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 4, image 3 de 3
    • Repeat the previous step to remove the top plate of the Xbox.
    Demander à FixBot
  5. How to Replace the Xbox 360 Optical Drive Belt: étape 5, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 5, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 5, image 3 de 3
    • Gently unhook all four clips located on the front of the Xbox.
    • Take care not to break the plastic clips; it may be fragile.
    Demander à FixBot
  6. How to Replace the Xbox 360 Optical Drive Belt: étape 6, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 6, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 6, image 3 de 3
    • Use the flathead screwdriver to gently press down on all of the indicated indents.
    • Remove the top casing from the Xbox.
    Demander à FixBot
  7. How to Replace the Xbox 360 Optical Drive Belt: étape 7, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 7, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 7, image 3 de 3
    • Use the T3 Torx screwdriver to remove all six screws.
    Demander à FixBot
  8. How to Replace the Xbox 360 Optical Drive Belt: étape 8, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 8, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 8, image 3 de 3
    • Carefully flip over the Xbox to the other side.
    • Lift the Xbox casing off.
    Demander à FixBot
  9. How to Replace the Xbox 360 Optical Drive Belt: étape 9, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 9, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 9, image 3 de 3
    • Unplug the two connections in the rear of the disk drive.
    Demander à FixBot
  10. How to Replace the Xbox 360 Optical Drive Belt: étape 10, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 10, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 10, image 3 de 3
    • Use a flat screwdriver to remove the four screws underneath the disc drive.
    • Flip over the DVD disc drive and remove the casing.
    Demander à FixBot
  11. How to Replace the Xbox 360 Optical Drive Belt: étape 11, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 11, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 11, image 3 de 3
    Outil utilisé dans cette étape :
    • Spin the located area with the flathead screwdriver to open up the disc drive.
    • Use tweezers to remove the belt drive.
    Demander à FixBot
  12. How to Replace the Xbox 360 Optical Drive Belt: étape 12, image 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 12, image 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: étape 12, image 3 de 3
    • Replace with a new drive belt.
    Demander à FixBot
8 autres ont terminé cette réparation.
Angel Lopez
Membre depuis le 02/28/23
421 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 60-7, Watkins Spring 2023 Membre de l'équipe Austin Community College, Team 60-7, Watkins Spring 2023
AUSTINCC-WATKINS-S23S60G7
1 membre
3 tutoriels rédigés
4 commentaires de tutoriel
I CANNOT get past step six. No matter how hard I pry, the pieces are not coming apart. I have pressed and twisted my screwdriver so much that it is damaging the plastic around it yet the pieces still stay together. What do I do?
Spencer Fantastic - Réponse Partager
Gotta buy the available 360 opener tool, its dirt cheap on aliexpress. Attempting via a screwdriver will just trash your case and get you nowhere.
Bootleg Joe (Snapman) - Réponse Partager
When I get to step 11, there is literally no opening to be able to spin the wheel manually to open it and replace the band. Step 12 shows 2 rectangular openings in the front of the DVD drive, mine is solid plastic with no open gaps. There must be different types of drives used. Right now I cannot get to the belt to replace it. Anyone see this other type of drive? Any thoughts?
Joe Heeney - Réponse Partager
@joeheeney there is a little bar that you can slide to the side, it will lower the laser and make you able to just kinda pull on the tray
Frey Kuijpers - Réponse Partager
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 120
30 derniers jours : 561
Total : 15,204
