Aller au contenu principal
How to Restring a Floyd Rose Bridge Guitar
Hasan28
Hasan28 et un autre contributeur
Dernière mise à jour le May 24, 2021
20 minutes
Modérée
Use this guide to restring any guitar with a Floyd Rose Bride, without compromising the action of your guitar. The guitar that I am using is my very own Jackson King V.
Before you begin, check what tuning your guitar is in because you want to make sure that you end up with the same tuning on all strings after finishing the restringing process. Also, you’ll need to match the previous gauge of the strings to your new ones, so it is important that the restringing is done with strings of the same gauge to avoid the bridge from loosing its position.
For step 3, I used a 9V battery to maintain the Bridge action. However, you can use any object that is almost close to the size and dimensions of a 9V battery.
  1. How to Restring a Floyd Rose Bridge Guitar, How to Restring a Floyd Rose Bridge Guitar: étape 1, image 1 de 1
    • Unlock the double locking screws under the headstock using the hex key.
  2. How to Restring a Floyd Rose Bridge Guitar: étape 2, image 1 de 2 How to Restring a Floyd Rose Bridge Guitar: étape 2, image 2 de 2
    • Tip the Floyd Rose Bridge forward by pushing down on the tremolo (whammy bar).
  3. How to Restring a Floyd Rose Bridge Guitar: étape 3, image 1 de 2 How to Restring a Floyd Rose Bridge Guitar: étape 3, image 2 de 2
    • Place a 9V battery (or similarly shaped object) in to the cut-out space under the bridge to hold the bridge steady.
    • When the 9V battery is in its place, you can now let go of the tremolo (whammy bar) and the bridge will stay steady for the process.
  4. How to Restring a Floyd Rose Bridge Guitar: étape 4, image 1 de 1
    • Unwind the old strings using the string winder.
  5. How to Restring a Floyd Rose Bridge Guitar: étape 5, image 1 de 2 How to Restring a Floyd Rose Bridge Guitar: étape 5, image 2 de 2
    • Loosen up the pegs that are below the fine tuners using the hex key, rotating counter-clockwise.
    • Gently pull the strings out of the block openings.
  6. How to Restring a Floyd Rose Bridge Guitar: étape 6, image 1 de 2 How to Restring a Floyd Rose Bridge Guitar: étape 6, image 2 de 2
    • Insert the strings one by one in to their respected block openings on the bridge.
  7. How to Restring a Floyd Rose Bridge Guitar: étape 7, image 1 de 1
    • Tighten up the pegs below the fine tuners using the hex key, rotating clockwise this time.
  8. How to Restring a Floyd Rose Bridge Guitar: étape 8, image 1 de 2 How to Restring a Floyd Rose Bridge Guitar: étape 8, image 2 de 2
    • Feed each string in through the tuners on the headstock.
  9. How to Restring a Floyd Rose Bridge Guitar: étape 9, image 1 de 3 How to Restring a Floyd Rose Bridge Guitar: étape 9, image 2 de 3 How to Restring a Floyd Rose Bridge Guitar: étape 9, image 3 de 3
    • Tune each string one at a time.
    • Cut the extra end of the strings after tuning using the wire cutter.
    • Finally, lock the double locking screws back using the hex key.
Hasan28
Membre depuis le 01/17/21
199 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G5, O'Regan Winter 2021 Membre de l'équipe York University, Team S1-G5, O'Regan Winter 2021
YORK-O'REGAN-W21S1G5
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 24
Total : 757
