Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to empty and clean Rival 16131 Toaster crumb tray
Ce dont vous avez besoin
    1. How to empty and clean Rival 16131 Toaster crumb tray, How to empty and clean Rival 16131 Toaster crumb tray: étape 1, image 1 de 2 How to empty and clean Rival 16131 Toaster crumb tray, How to empty and clean Rival 16131 Toaster crumb tray: étape 1, image 2 de 2
      • To open the crumb tray, pinch the lever in the photo.
      • If the lever does not keep the the crumb tray closed, stretch the lever so that to make sure the two horizontal pieces are aligned.
      Demander à FixBot
      Ajouter un commentaire
    2. How to empty and clean Rival 16131 Toaster crumb tray: étape 2, image 1 de 1
      • Now that the tray is exposed, it is possible to clean the face here.
      • Try to not let water get into the toaster as this may damage the heating coil.
      • If the tray can not be cleaned simply by opening it, keep going through the guide to fully remove it.
      Demander à FixBot
    3. How to empty and clean Rival 16131 Toaster crumb tray: étape 3, image 1 de 3 How to empty and clean Rival 16131 Toaster crumb tray: étape 3, image 2 de 3 How to empty and clean Rival 16131 Toaster crumb tray: étape 3, image 3 de 3
      Outil utilisé dans cette étape :
      • To remove the tray, the metal hinges must be bent up.
      • While applying pressure to the bottom of the toaster, use pliers or tweezers to bend up the bracket. The pressure applied to the bottom of the toaster should be just enough to allow the bracket to swing up.
      • Remove the tray and clean.
      Demander à FixBot
Grant Haug
Membre depuis le 09/26/12
148 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 2-8, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 2-8, Propen Fall 2012
CPSU-PROPEN-F12S2G8
5 membres
18 tutoriels rédigés
1 commentaire de tutoriel
Thanks! This was helpful. :)
Tracy Emmanuel - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 54
Total : 3,906
